cams for an 07
Old Jun 25, 2007 | 07:47 PM
rutgersengr's Avatar
cams for an 07
Does anyone know of any cams for an 07 lt. As far as I understand there are none because of the cam sensor. Will the ones from gm work pn 88958698. I just want a mild cam that does not require a retune.
Old Jun 25, 2007 | 08:08 PM
YSUsteven's Avatar
So waht is the point of getting new cams if there is little defference. You have to beable to tune for it to make a significant difference. Do you really want to pay $800 for 2 horses?
Old Jun 25, 2007 | 10:23 PM
I want one that does not REQUIRE a retune. that does not mean I cannot/wont do one when the softwear comes out. There are camsets out there in the 4-500 dollar range.
Old Jun 25, 2007 | 10:29 PM
exiged's Avatar
www.turbotechracing.com
they have stage1 cams your can order off there page that do not require a tune..
however i have heard sct is within a month or 2 to realeasing there tuning solution so im kind of waiting to see what happens with that. because my plans for the car are going boosted i would like to get a different grind then the stage 1 ideally, but i guess well just have to wait and seee
Old Jun 25, 2007 | 10:51 PM
I saw those but was not sure if they would work because I thought the cam sensor changed for 07 and those are only listed to 06
Old Jun 25, 2007 | 10:57 PM
Halfcent's Avatar
I'm old school
Merged duplicate.
You are correct. The 2007 L61 has a completely different exhaust cam, and none of the previous L61 designs will work with it. To the best of my knowledge, nobody makes a set. And if I had to guess, nobody will now that the Ecotec line has expanded to higher performance models.
Old Jun 26, 2007 | 09:15 PM
YSUsteven's Avatar
The reason that I said $800 was because if you take it to a good shop, it might take a couple of hours of labor. So three hours labor, at $60 an hour, thats around 680 total, plus tax, yada, yada. So $800 might be a little high, how bout $700
But you are still looking at $700 for 2 hp, does it sound worth it.
My opinion is hell no. You can get much better bang for the buck by just adding bolt ons.
Old Jun 26, 2007 | 09:18 PM
jeremie's Avatar
couldnt you jsut get blank cams and have them custom ground? or order a custom ground cam? the cam sensor shouldnt be a problem as long as your new cams have a reluctor on them
Old Jun 27, 2007 | 01:27 AM
exiged's Avatar
yea but depending on what you do, its the same situation, i would think.
Old Jun 27, 2007 | 01:40 AM
07LSC's Avatar
Honestly, if you're going to go through the trouble of doing cam swap(s) you're gonna want it to make a big difference. I say this having done cam swap before (though it wa more difficult having been on a pushrod motor and half the motor is stuffed under the dash on the freakin thing). Before I got the camaro tuned it still ran fine, a little lean up top and stalled about once a week at a stoplight (which considering how many stoplights a day i sat at that's really good) but ran nicely and loped like a monster. My advice, if you're swapping cam(s), think big
Old Jun 27, 2007 | 07:40 PM
YSUsteven's Avatar
No thats what I'm talkn' about. Just wait for tuning a couple more years and you'll be all set.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
