Cams on N/A
Old Aug 8, 2007 | 01:22 PM
tonio5555's Avatar
Cams on N/A
Is anyone running cams such as these on a N/A 2.2 Cobalt?
http://www.turbotechracing.com/produ...idproduct=2450
http://www.crateenginedepot.com/stor...-P320C141.aspx
I'm thinking down the road after I finish doing all the bolt ons about where I want to go with the car. I'm not interested in forced induction, I just want to pump some extra power out of the motor while I wait for the 2009 Camaro.
Old Aug 8, 2007 | 01:30 PM
g5mike's Avatar
I think some members may be running those or JBP cams
Old Aug 8, 2007 | 01:38 PM
tonio5555's Avatar
I've been doing some thread searching and I realize tuning is really vital to getting these cams to their full potential... maybe I should email HPTuners....AGAIN lol.
Old Aug 8, 2007 | 03:54 PM
Bryank930's Avatar
You'd be wasting your time.
Old Aug 8, 2007 | 03:58 PM
XM15's Avatar
If you want to get cams, I would also suggest doing some headwork as well. It won't be cheap, but you'll have a pretty nice n/a setup once you're done.
Old Aug 8, 2007 | 04:07 PM
g5mike's Avatar
what he said,^^^^^ head&cams make for a happy engine.
Old Aug 8, 2007 | 04:10 PM
TurboTechRacing's Avatar
On the stock computer the Comp Cams stage 1 will get you around 10 HP on a stock engine. With HP tuners i could bet you would see around 12-15 with these cams with additional tuning.
However, these cams work very well for being a direct drop in with no other mods needed.
Old Aug 8, 2007 | 04:24 PM
Sw4y1313's Avatar
Its very possible to use a piggyback to tune for some bigger cams. You could use the AEM FIC to run stock LSJ injectors and increase fuel where its needed.
Old Aug 8, 2007 | 04:28 PM
g5mike's Avatar
Dont know about your 2.2 but on a 2.4 stage 2 cams dont need tuning..tuning will net greater results,but my powerband loves its intake cam..
Old Aug 8, 2007 | 04:32 PM
The_Blur's Avatar
It's still strongly recommended that tuning is used for best results. Why buy something and not use it to its full potential?
What tuning options are available through piggybacks?
Old Aug 8, 2007 | 04:40 PM
Spanky's Monkey's Avatar
2.2 cams don't work for the 2.4 and vice versa so that's really a dead issuse in the door. i am interested in these stage 1 cams though.
Old Aug 8, 2007 | 04:41 PM
Sw4y1313's Avatar
AEM Fuel/Ignition Controller, PerfectPower SMT-6/7 and UniChip Q are the only ones I know of that will work. AEM FIC is by far the best because of its feature to allow for you to run larger then stock injectors.
Old Aug 8, 2007 | 05:09 PM
tonio5555's Avatar
I know, the 2.2 ECM is always "in development, but not scheduled to be released on our next cycle.... etc etc etc" FTL!
Old Aug 8, 2007 | 06:52 PM
rutgersengr's Avatar
not surt if the 06 are the same but the 07 have a cam sensor and i believe there are currently no cams avalable that will work with the sensor
Old Aug 8, 2007 | 07:16 PM
YSUsteven's Avatar
I believe that the cam sensor was added for the 2007 as well as other motor tweaks, including a more melow stock cam.
Old Aug 8, 2007 | 07:24 PM
g5mike's Avatar
whats ya sayin willis.LOl. we all have cam sensor,i know this one first hand and i'm an 06
Old Aug 8, 2007 | 08:51 PM
Novajoe's Avatar
I wouldn't add camshafts untill you have things like a bigger tb, intake manifold, and a header. Some kind of tuning is preferred too. Sure there's camshafts out there that you could throw in there for some gain... but there's better ways to spend your money for gains unless you have at least some bolt-ons and tuning. Figure you're going to spend about $200 per camshaft(intake and exhaust. not including installation costs and other minor parts like gaskets and such you have to replace when taking it all apart.)... and you're only gonna get 10hp out of it, which might not even be at the wheels.
While you're changing out your camshafts it might not be a bad idea to port match while you have it all apart either.
Old Aug 9, 2007 | 12:04 AM
IonNinja's Avatar
if you're staying N/A I wouldn't even bother with any cams that are going to run out of breath by 6500.
I am dying to drop some cams into this motor but its pointless right now for me because theres no way to bump up the stock redline.
Old Aug 9, 2007 | 12:07 AM
g5mike's Avatar
just go with tri-flows i got nice power throughout my power band,ya it might be willing to give a little more.
Old Aug 9, 2007 | 12:41 AM
NextLevel's Avatar
Did you tune at all?
Old Aug 9, 2007 | 07:48 AM
g5mike's Avatar
untuned,at the time HPT did not have a whole lot goin for it,in way of tuning the cams,plus I could not find a shop to use HPT
Old Aug 9, 2007 | 11:59 AM
NextLevel's Avatar
those are the ones that can go n/a or forced right?
Old Aug 9, 2007 | 12:02 PM
g5mike's Avatar
thats correct,I'am FI in the next few months,this is where the tune comes in.LOL!!!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
