Cat back installation?!?!
Old Jun 13, 2006 | 08:12 PM
eazyasone23's Avatar
I just got my cat back exhaust, and I tried to install it, but the bolts off the CAT were too damn rusted, actually they were frozen on. Has anyone else had this problem and anyone have some suggestions for taking them off. I did it by hand plus I couldnt get them off with air tools. Thanks guys
Old Jun 13, 2006 | 08:16 PM
D4u2s0t's Avatar
WD-40?
Old Jun 13, 2006 | 08:17 PM
hatrickstu's Avatar
use this stuff called PB blaster i belive, white can, with yellow top in an aersol bottle
Old Jun 13, 2006 | 08:18 PM
will that really work or should i attempt to cut them off? isht im mad because i wanted to install it today. guess imma hafta do it next week now
Old Jun 13, 2006 | 08:21 PM
Chevypowered's Avatar
Spray them down with WD-40 and let is sit for 20 minutes, that should loosen them up!
Old Jun 13, 2006 | 08:34 PM
mkulrey13's Avatar
I used WD-40 with my cat back and it worked fine
Old Jun 13, 2006 | 10:42 PM
ok ill pick up a can and try the wd-40 and the pblaster
Old Jun 14, 2006 | 08:04 AM
sjsmal07's Avatar
PB blaster works magic in these situations. I've been able to get bolts off of morings that have been in the water for years because of this stuff. You should be able to find it at any autozone or advance auto too!
Old Jun 14, 2006 | 10:50 AM
mike25's Avatar
whatever you do dont try to cut them...if that goes wrong you might end up having to retap the screw(drill it out) which is a bitch..just use the wd-40..itl work fine..
Old Jun 14, 2006 | 11:30 AM
Halfcent's Avatar
I'm old school
It is better to break the bolt off in the hole then it is to cut it off. Get a large breaker bar and torque the nut until it loosens or breaks off. With exhaust bolts, if they break, they just slide out of the holes, and you can get new ones. If you cut stuff, you damage the actual exaust components.
Old Jun 14, 2006 | 12:37 PM
CobaltLT's Avatar
PB Blaster should work just fine, all the techs around here use it. WD-40 should work as well.
Old Jun 14, 2006 | 01:00 PM
hatrickstu's Avatar
no no no NAPA auto parts, haha, my dad works for them
Turbo Johnny
Feb 21, 2019 09:41 AM
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
jmelton327
Sep 25, 2015 09:44 AM
