Cisco2.2build
Old Nov 22, 2011 | 10:56 PM
cisco123's Avatar
Cisco2.2build
I have an 07 2.2 sc went to the junkyard got an 07 2.2 motor need info on a build looking to break 350hp with the blower and able to hold the power safely
Any info would help
Old Nov 24, 2011 | 05:47 AM
cisco123's Avatar
Any help website to buy the parts I need
Old Nov 24, 2011 | 06:14 AM
FrossB's Avatar
Thread Killer
are you dead set on a supercharger?
Old Nov 24, 2011 | 11:12 AM
cisco123's Avatar
Yes not changing just want some strong safe power
Old Nov 24, 2011 | 11:17 AM
Switt23's Avatar
You can check eBay for the Eagle Rods and Wiesco Pistons.. I don't recall the member's name but someone might chime in.
There is a guy that sells them cheap as a set.
Old Nov 24, 2011 | 11:20 AM
cisco123's Avatar
Is that the main thing to change out what about port and polish
Old Nov 24, 2011 | 11:23 AM
soundjunky's Avatar
I'd suggest you look up LSJ builds and their power attained - you're going to need to do pretty much the same...
uphill battle for sure.
EDIT;
Here let me help you get the ball rolling;
https://www.cobaltss.net/forums/dyno...2011-a-247552/
Old Nov 24, 2011 | 11:36 AM
Switt23's Avatar
The rods are the weak part of the 2.2Ls. Ours are not forged. But if you are shooting for 350whp that passes what the LSJ was rated for too, so your going to be building just like what was stated above.
Old Nov 24, 2011 | 12:19 PM
cisco123's Avatar
Ok thanks for the help much needed
Old Nov 24, 2011 | 12:34 PM
cisco123's Avatar
Old Nov 24, 2011 | 12:43 PM
Dart_SI's Avatar
your going to need a TVS
Old Nov 24, 2011 | 12:52 PM
08baltls's Avatar
I'm in the same boat as you looking to build close to 300hp. I'm gonna be doing most of the work myself and so far I've fogured around $15,000 for safe and reliable power like that on a 2.2L. So if you're looking for 350hp be prepared to.spend that at least unless you're using used parta and doing every bit of it yourself.
Old Nov 24, 2011 | 01:10 PM
soundjunky's Avatar
has anyone looked at that dyno thread?
that's in the price range of buying an SS/TC (especially if you factor in selling your car to offset costs);
if this is the case don't let yourself get sucked into the whole logic of "well I built it myself" - because that's just nutty.
It has been proven that a bone stock SS/TC with a tune only can make 300whp.
Aside from the obvious engine upgrade that an SS/TC would get you, you would also get better:
  • seats
  • transmission
  • shifter (short throw)
  • wheels
  • brakes
  • springs (suspension)
  • shocks & struts (suspension)
  • stereo system & deck (just guessing here)
if you doubt that an SS/TC can make 300whp, I'd re-direct you to the dyno thread, look at number #28 in the "2.0 T/C Stock Turbo" group - read his mod list.
You could do somethign similar with an SS/SC - but look at the stock blower list (only two make more than 300whp), or the anythign goes list - eight of those guys (five of which list a TVS) don't even hit 300whp...
Not only are all of these facts legit, but at the end of the day a heavily modified car is going to be a tough sale for when you need to move on...
If you're worried about higher insurance rates for an SS - you might want to look into clauses that most ins companies have for modified cars...
Old Nov 24, 2011 | 01:19 PM
08baltls's Avatar
Yeah I looked at the dyno thread. Its got me wondering if.I should build or just.buy something different entirely. Haha. 300hp in a fwd car isn't exactly that grand to me. I honestly doubt I'll wanna drop that kinda money on a car like this.
Old Nov 24, 2011 | 01:33 PM
soundjunky's Avatar
it's totally doable - but you get better parts with the 'level 4' cars...
Gm Used the level system to differentiate w/o model name, based on std equipment
base = Level 1
LT/LS = Level 2
SS(2.4)/Sport = Level 3
SS-TC & SS-SC = Level 4
level's 1-3 essentially were the same cars - they got the same interiors, transmissions, suspension ect;
level 3 was essentially a bigger engine combined with rear discs over the level 2...
level 2 is trim & std items over the base.
...but back to your post;
300whp isn't a big deal - but a 300whp base model cobalts is still only a base cobalt;
mods do not increase a cars value - as a matter of fact they often detract from the overall value.
If you were wanting to stay naturally aspirated, a pre-2008(?) L61 Cobalt would be my personal choice - but even then 300whp is going to be barely streetable, and chronically unreliable... 200bhp would be a more realisitic goal.
Old Nov 24, 2011 | 01:46 PM
08baltls's Avatar
Well I've got a 2008. But my.plans for getting close to 300hp also consisted of a TVS blower and NOS. Haha
Old Nov 24, 2011 | 01:49 PM
rcarr0327's Avatar
https://www.cobaltss.net/forums/2-2l...-boost-240401/
https://www.cobaltss.net/forums/adva...-build-253266/
both turbo build but they both replaced what ur looking at. ill see if i can find a blower thread
Old Nov 24, 2011 | 02:08 PM
cisco123's Avatar
M62 sc with bulid motor wont break 300
Old Nov 24, 2011 | 02:13 PM
cisco123's Avatar
I guess I better bring the 300hp down I want to dyno my car as is it has cai m62 kit light wight crank pully psce setter header dp combo 3" stock ss/sc catback and s3 h/e from zzp
Old Nov 24, 2011 | 03:35 PM
soundjunky's Avatar
look again;
that list begs to differ.
Old Nov 24, 2011 | 03:47 PM
jonathan923's Avatar
internal work like pistons, rods, cam, port and polished head, ported m62+2.8 or 2.7 pulley, injectors, all suporting mods like exhaust, intake, headers, E85 and a good tune id say youll be right around the 300whp range on your 2.2
for 350whp your gona need a tvs and probably some more work
Old Nov 24, 2011 | 03:49 PM
rcarr0327's Avatar
is it me or does it seem easier to get 300hp out of a 2.2 with a turbo than a supercharger? could be biased, just dont know much about blowers
Old Nov 24, 2011 | 06:52 PM
cisco123's Avatar
Thats about all im going to do
Old Nov 24, 2011 | 07:11 PM
concider a clutch too. and am not so sure how a 2.2 tranny will handle that kind of power but thats one thing to keep an eye for.
Old Nov 24, 2011 | 08:05 PM
cisco123's Avatar
About how much is it to do all that
