compression test
Old Mar 18, 2009 | 08:04 PM
NWAE Cobalt's Avatar
compression test
most of you have seen my troubles in my buiild thread...
but tonight im going to pick up a compression tester at schucks (only 25$) and test the car to make sure im building compression...what should i be looking for as far as readings?? whats normal?
anything i need to know special about our cars before i go do this tonight?
Old Mar 18, 2009 | 08:09 PM
Jn2's Avatar
Jn2
crap i dont remember, all i know is they should all be around the same #
Old Mar 18, 2009 | 08:14 PM
boostedss26's Avatar
What year is your car? i can look on alldata
All alldata says is no cylinder reading should be less than 689kpa or 100 psi
Last edited by boostedss26; Mar 18, 2009 at 08:14 PM. Reason: Automerged Doublepost
Old Mar 18, 2009 | 08:16 PM
cool cool, its an 06 ls
so if its below 100psi then i have a leak...?
Sentry's Avatar
I thought all cylinders should be around 130-150 psi. Just from what I remember, could be off a little though.
Old Mar 18, 2009 | 08:22 PM
ok i looked up an 06. You don't want any more than 25 psi difference between cylinders though if i remember correctly
Old Mar 18, 2009 | 08:24 PM
ok, cool cool, will check tonight and post some results
Old Mar 30, 2009 | 01:27 AM
never posted results lol, then went out of town haha
its at 0psi...
pulling the head and checking for bent valves this week
Old Mar 30, 2009 | 01:38 AM
~Mike~'s Avatar
Dumb question cuz I've never had to do it or known someone that has, but how do you check compression? I think I might have a problem, but I don't wanna take it to the dealer and have it gone for a week or however long they think they need to make me wait
Old Mar 30, 2009 | 01:49 AM
you buy a tester (mine was 30$ at schucks), pull a spark plug, instert the tester, pull the fuel injector fuse so you dont get fuel, and turn it over 3-5 times and read the compression, do this to all cyl and check the numb, all 2.2l i have done show between 170-190psi...and i think they are supposed to be within 15psi of each other. if it shows low, then drop a few drops oil and try again, if that fixes it then you have worn rings or cyl walls. if it doesnt then head gasket or valve problems
Old Mar 30, 2009 | 02:07 AM
~Mike~'s Avatar
well mines a 2.0, not 2.2 so i don't know if my compression numbers would be the same, but I'll check into that tomo since I have the day off. Thanks for the info...I keep smellin antifreeze from my exhaust, so i hope this helps me track down the issue
Old Mar 30, 2009 | 02:42 AM
from what im told, that sounds like a head gasket issue
Old Mar 30, 2009 | 02:47 AM
Nighthawk243's Avatar
It may also be a leaking line putting coolant on the exhaust manifold. I think the thermostat housing is toward the back.
Old Mar 30, 2009 | 02:48 AM
~Mike~'s Avatar
Honestly, that's what I'm hoping. It's alooooot easier than replacing piston rings or valvetrain components. But, can't hurt to double check my compression and make sure. If i do a head gasket myself and have to take it back to the dealer later for something, are they gonna know? and would it void out my warranty?
Old Mar 30, 2009 | 02:59 AM
would they know?? i suppose they might if you use diff bolts (aftermarket not gm head bolts) or a none gm head gasket...and if they did im sure it would void the warranty
Old Mar 30, 2009 | 03:02 AM
Just use GM parts... you should be able to order the bolt set and gaskets off of crate engine depot or GMPD or something.
Old Mar 30, 2009 | 09:25 AM
PSHHH's Avatar
or just dont do any lower block damage next time you take it to them so they never get to the gasket
Old Mar 30, 2009 | 09:51 AM
Red07SSNA's Avatar
To do a proper compression test you have to remove all the spark plugs, disable the ignition and fuel system, insert the compression gauge in one spark plug hole at a time, and crank the engine at least 4 cycles each test. Having all the spark plugs out allows the starter to crank the engine for the test -- it doesn't have to "fight" the non-tested cylinder's compression during the test.
hacadacalopolis
Oct 28, 2015 06:09 PM
Tupp
Sep 30, 2015 08:18 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
