Crank Problem Still
Old Jun 23, 2012 | 03:30 PM
mrw5641's Avatar
Crank Problem Still
Hey all, I still am having an extended engine crank problem / RPM fluctuation as start up. The weird thing is I can have 10 good starts in a row. Then it cranks... I changed the spark plugs and I am still having the same problem. Any ideas? The only thing I am unsure of is where the hose on this piece goes, also could be causing the problem
I have 2.2L LT / SC bolt on kit. Tuned.
Old Jun 23, 2012 | 03:35 PM
Sunburst_SS's Avatar
that port is for the boost control solenoid....your car doesn't have that. So you can just cap that off if you want to.
Now for the extended crank.....does this happen after it sits overnight or something?
Old Jun 23, 2012 | 04:13 PM
mrw5641's Avatar
Thank you for step 1 :p. No it can happen at random. For example I put the new plugs in, started up right away. Turn it off and started it up again and then the crank. So on an so forth. Also the rpm spikes happen at random also.
Old Jun 25, 2012 | 12:16 PM
bluebalt07's Avatar
Probably shouldn't cap that port off. On the 2.2 and 2.4 it is supposed to be left open
Old Jun 25, 2012 | 01:25 PM
mrw5641's Avatar
Ya, I planned on leaving it open. Just trying to figure out my cranking problem
Stuff
Oct 1, 2015 05:47 PM
cw383
Sep 30, 2015 12:41 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
