Drumrush's build thread
Power Enrichment mode.Basically,your afr's should gradually enrich as you put more throttle into it and as boost increases.How he tunes is as soon as you hit any positive manifold pressure(boost)it kicks into PE mode which is a set AFR.So if your passing someone and hit boost in 5th gear at say 2000rpm ,your afr's go to whatever its programmed to.If i'm at 2000 rpm and set it on 1 pound of boost,it drops to 10.5:1 afr.He doesnt factor in Throttle position at all.With hpt,everything is factored in.The TF tune kills my mileage because of this.
Tundraboarder666.He's built motor and trans on E85 via hpt.****** is fast!
My TF NA tune was good.My afrs at idle are all over the place and timing spikes at idle as well.Idle is all over the place and sounds like its cammed.Ive had multiple people ask if im cammed im like" uhhhh yeah!its got stage 1 blower cams"
I'm not a tuner by any means which is why im having a buddy tune it for me via hpt.
i know a little about tuning but not enough....yet
This is how fast his car is..We ran from a 60 roll.He only gave it 30% throttle at around 12-14 psi.I hammered it 100% throttle.he pulled me by about 4 cars.No lie.he was toying with me and decimated my car.My car runs mid 13's in the quarter.Imagine what his will run.
yeah, thats the only thing im still confused with. i have a complete understanding of how to hook up the cooling system, but attaching those 2 parts are confusing the hell out of me haha
i just got off the phone with the guy whos selling me the kit, hes got the alternator bracket, idler pulley, tensioner, stage 2 belt, and everything else ive mentioned. hell, hes even sending all of the bolts even though i just ordered them
