Engine codes
Old Mar 30, 2016 | 09:54 PM
freakta's Avatar
Engine codes
B2aaa
P0443
P0141
P0135
P0102
P0054
P0053
P0036
P0030
Help?
When I clear them, the car dies. Starts back up and dies. Does this a few times. When you press the gas pedal it dies off. Eventually it will stay running with you foot on the gas. But has these codes pending
P0030
P0036
P0102
P0443
B2aaa
Old Mar 30, 2016 | 11:07 PM
LsCobalt07's Avatar
Check the EXH fuse under the hood as well as the wiring to the O2 sensors.
Old Mar 31, 2016 | 10:29 AM
freakta's Avatar
Thanks I'll check those. Ran out of daylight yesterday
Old Mar 31, 2016 | 11:34 AM
check all the fuses
Old Mar 31, 2016 | 11:42 AM
freakta's Avatar
How many fuse boxes do we have
Old Mar 31, 2016 | 12:55 PM
Kobraa's Avatar
Oi bruv
Old Mar 31, 2016 | 01:12 PM
freakta's Avatar
Thanks for that.
He said it started to give him trouble after he used an autozone key fob programmer on the car. Said it was obd2. But I'm sure he doesn't know what he plugged where and what he was doing.
Old Apr 1, 2016 | 08:04 AM
Kobraa's Avatar
No problem. I got the hookup for schematics, bullitens, pinouts, etc. More than happy to help
Old Apr 1, 2016 | 10:21 PM
freakta's Avatar
It was the exh fuse. Thanks for all the help
Old Apr 5, 2016 | 04:01 PM
freakta's Avatar
Codes came back... any ideas what causes these? What does the exh fuse control? I need to start to diagnose this and actually fix the problem
Any suggestions?
Old Apr 5, 2016 | 05:07 PM
Kobraa's Avatar
oi again bruv. complete circuit for that fuse.
Old Apr 5, 2016 | 05:09 PM
Kobraa's Avatar
Educated guess based on all those o2 codes: If your fuse is popped again you either have a wire shorting to ground or a sensor itself is shorting internally. If the fuse is repopped, id unplug 1 of the 2 o2 sensors, turn your key on, and see if it repops. If not, you know the problem is with that sensor. If you unplug both and that fuse still pops, you have a short to ground.
Old Apr 5, 2016 | 10:05 PM
freakta's Avatar
I assumed it was a wire melted to the exhaust
MitchSS
Apr 20, 2016 11:04 AM
Snail_SS
Mar 29, 2016 10:15 PM
Timnman
Mar 13, 2016 03:00 PM
zerosk8ter83
Mar 11, 2016 03:08 PM
09SS7163
Mar 10, 2016 12:30 AM
