engine reflash
Old Jan 29, 2008 | 11:13 PM
KyleMinnis's Avatar
engine reflash
ive heard of getting an engine reflash done, and can get you anywhere from 10 all the way to 80 HP....???
is this true???
i hear it is around 500 or so dollars to get that done...?
i may be wrong though
Old Jan 29, 2008 | 11:18 PM
Red2.4SS's Avatar
you are more likely to see 10-15hp maybe 20 at most!
I don't know if tunning is out yet for the 2.2L though?
scotty1979's Avatar
If you get a S2 and have the SS/SC yes this is true. Not for us 2.2s though.
Old Jan 30, 2008 | 07:32 PM
YSUsteven's Avatar
is this true???
80 HP,
That would also be nearly 50% more power that the engine outputs. Even if it was an SS/SC, thats about 40% more power. GM must have some really stupid engineers if their engines are running at 60% of what they can stock.
There is no tuning available for 2.2s, please do a search next time.
Old Jan 31, 2008 | 11:46 AM
RedBaseBolt's Avatar
In order to add or subtract fuel for our cars you need to run Full engine management or a piggy back ECU.
Old Jan 31, 2008 | 02:00 PM
montecarloman's Avatar
Or if you have access to a tech 2 you can keep track of the fuel tables. Just install less and less restrictive intakes and filters.
Old Jan 31, 2008 | 02:26 PM
You need a scan tool to monitor yes, but you can't tune with a scan tool.
You need a piggy back like the AEM FIC to do that.
Old Jan 31, 2008 | 08:10 PM
hugemurph4's Avatar
The reason why you cant tune the 2.2 is because there are throttle codes and engine codes...yea you can reflash the engine codes, but the throttle codes came from a totally differant company. The codes wont match up and the computer will throw a codes to not have your car start. but if you can contact the group who did the throttle codes and ask them what to use they will give them to you like what they did to me. I was able to get my govenor removed, advanced my spark a tiny bit and was able to lean out on full throttle situations.QUOTE=YSUsteven;1896758]80 HP,
There is no tuning available for 2.2s, please do a search next time.[/QUOTE]
It also helps when your good friend reflashes computers for GM and can get all of that info for free too
Last edited by hugemurph4; Jan 31, 2008 at 08:10 PM. Reason: Automerged Doublepost
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
