getting rid of ur govner?
Old Oct 25, 2006 | 02:26 AM
  #76
3fo893013L's Avatar
For those who misunderstood my original post. like 8 months ago..
I drive a 2.2 LT Sedan as well that has the 16' rims and Pirelli P6 tires w/the flash for top end. I don't see a need to go over 80 in my sedan because the car wasn't built to go that fast anyways. Just because the speedometer says it can doesn't mean you should.
Think GM should flash the computer just so you get a few more MPH on top end? What will this prove? Your basically asking them to adjust it so you can kill someone or yourself.
Old Oct 25, 2006 | 02:34 AM
  #77
importkiller's Avatar
ok the 2.2 cobalts can not take turns like the ss's so there is no reason to make them faster, you prove nothing with top speed, it is all about 0-60 and slalom #!!!!
Old Oct 25, 2006 | 03:26 PM
  #78
biohazard's Avatar
Get low
sorry but that was one of the most ignorant post ive seen latly.... yes i have a 2.2 but im unbiased on it.... but for one i want my govener gone so i can dyno my car, 2 base modles can take turns identical to the SS once you swap some suspencion parts... and 3rd, some people want top speed, others it just sucks knowing your stuck at 105 mph and then no matter how much you mod it, your only going to go 105... just somne food for thought
Old Oct 26, 2006 | 04:54 PM
  #79
SIMMONS 2.0's Avatar
just go to a cool dealer like i did and show them u have new tires and rims rated for higher speeds and u can get the tire size changed and effectivley remove the 105mph gov...this will NOT remove the fuel cut off though...NEVER do that
Old Dec 7, 2006 | 12:42 PM
  #80
neontj's Avatar
not to bring this thread back to life but any of the pcm updates done by gm will take the cobalt up to the ss top end limiter. just done it to mine for a c.e.l. and no more 105 it will pull 4th and continue in 5th to bad my speedo dosen't read past 120.
Old Dec 17, 2006 | 02:13 PM
  #81
Delta2.2's Avatar
so your hitting past 105 now. you just went to a GM dealer and they did it for ya? explain?
Old Dec 18, 2006 | 12:32 PM
  #82
neontj's Avatar
no i work at a dealership so will any one do it for you i don't know i just done it to mine to correct a problem and it happend to erase the limiter too. kind of a two for one. 05's have problems with running lean and the update richens it up and the update is what deleates the limiter.
Old Dec 18, 2006 | 08:14 PM
  #83
IonNinja's Avatar
I saw that there was an update for a lean code for my car but I was at a chevy dealership at the time so the flash wouldn't work.
I'm going to try to go to a saturn dealership and see if they can flash me. While I was at the dealership I was also told that my tire size is actually set to 16" yet my limiter is still at 108. Then I hear from another cobalt member that its actually the tire rating that they change, not the tire size that will effect the governor.
I'm gonna try to get a flash, hope they don't look under the hood though...or in the trunk
Old Dec 18, 2006 | 08:16 PM
  #84
D4u2s0t's Avatar
take the bottle out, or cover it up!!
and yea, it has to do with the rating of the tire, not the size
Old Dec 18, 2006 | 08:32 PM
  #85
rally's Avatar
IonNinja the chevy dealer should have been able to give you your update. Saturns dont use any special equipment.
To flash or "update" the pcm all they do is plug in a Tech 2, retrieve the vin, goto TIS WEB, upload the new software to the tech 2, take it to the car and download it. Super easy.
Old Dec 18, 2006 | 08:51 PM
  #86
IonNinja's Avatar
He had my car plugged into a Tech 2, he was able to retrieve my VIN and see the update but for some reason he was not able to actually download the software.
Old Dec 18, 2006 | 09:09 PM
  #87
DaREDss's Avatar
yo im curious wut is the ss/sc limit at? i keep tryin to take it up but i dont get out of 4th gear
Old Dec 18, 2006 | 11:05 PM
  #88
IonNinja's Avatar
the SS/SC limit is at about 160mph
Old Dec 18, 2006 | 11:28 PM
  #89
DaREDss's Avatar
thanks
Old Dec 19, 2006 | 08:11 PM
  #90
NP05Cobalt's Avatar
i asked my dealership to raise my governor but they said they couldnt... they had to reflash my computer anyways so maybe it automatically did it? i dnno but maybe ill try my other dealer north of me
Old Dec 27, 2006 | 08:37 PM
  #91
nimble's Avatar
re-govena removal
Just wondering if anyone was able to get GM to remove the govenor(105) cut off. I'm still waiting patiently for the pcm tune. It is real gay having a car that can go over 105 and can't. My 1994 z24 5-speed pulled like crazy...all the way to 108 then.....govena! Raced a chrysler mini-van down I-57 south and it zoomed past me. Embarassing to me to say the least. So you SS guys should not even trip about us wanting to go a little faster...insecure???!!!! Any-way when someone finds a fix, give me a pm.
Old Dec 27, 2006 | 09:12 PM
  #92
NKs07CobaltSS's Avatar
Originally Posted by iso
i wouldn't suggest rigging your car to exceed your governor until you get some better tires. having a blowout at 110+ mph doesn't sound like fun to me. also, to everyone that is complaining about how the 2.2 is better because you can make it faster than an ss/sc with less money overall... that's wonderful and good for you! but i'm still content with keeping my warranty. if warranty is no big deal, than have fun modding your car, there's no need for everyone to throw stones. we're all here because of 1 simple reason... we all LOVE OUR CARS! let's get along. it's going to be interesting in the long run to see who makes it to 10's first... a 2.0, a 2.2, or a 2.4. that's where it gets tough, getting some really good times isn't all about hp, you're going to need to be able to put that power down with a great suspension... so i guess we'll have to see which car is a better starting platform.
My sentiment sexactly Sounds to me that things have escalated in this thread and Even as ss/sc owner would never say anything bad about someone who chooses to buy the ls model this isn't a place for arguing the car is a good car and we all know that $$$$dollars make horsepower! This thread has been saddening to watch because thats not what this forum is about ! Just my peice of mind
They will come out with a chip set to over come the govener i wouldn't suggest any other way to do so!
Old Dec 29, 2006 | 04:40 PM
  #93
RollermanDan's Avatar
Went to my dealership today to pick up my car after it's had some problems (that's another story) but when I dropped it off on Wednesday, I asked them to see if there is a reflash to raise the governor on my car and they said they'd look into it. I was told today that there isn't a reflash for that or if there is, they wouldn't do it because of warrenty. Oh well, just gotta wait til something comes out for it...
Old Dec 30, 2006 | 12:54 AM
  #94
lil_kano's Avatar
Ok. from what im understanding in this thread, there is no actual update to raise/remove the govenor, but with the update for the car running lean, it raises/removes the govenor as a little bonus. Now, is going to the dealership and asking for this free?
Sean Cummings
Oct 31, 2015 06:32 PM
camaromanss1992
Oct 1, 2015 10:51 PM
OrangeCoba
Sep 29, 2015 03:56 PM
dieGone
Sep 23, 2015 10:20 AM
Haily229
Sep 17, 2015 07:18 AM
