How is this sounding so far..?
Old Dec 19, 2009 | 02:13 AM
xxxxsh4d0wxxxx's Avatar
I'm still going on my NA build and I want to know what my fellow 2.2L's think of it..
Have:
-ARK GRiP cat-back: 2.6" piping
-Injen CAI
-2.4L Intake mani
On it's way:
Clear Image Automotive 4-1 header with 1 5/8" primaries, ceramic coated. Clear Image Automotive DP 2.5" with high flow metallic cat and extra o2 bung for wideband.
Few months from now:
-2.4L TB swap
-Trifecta tune
Should be done by spring.
Old Dec 19, 2009 | 02:20 AM
Maven's Avatar
I think the header is toob big. Id use a CIA 1 5/8"
Old Dec 19, 2009 | 02:21 AM
OriGinaL Condo's Avatar
Vibrant sounds amazing on my LSJ and I definitely felt the improvement when I first installed them. Only problem I've had is that the collector is pretty small for high horsepower numbers. If you're staying NA with a 2.2L I don't foresee the collector being too big of an issue for you.
Old Dec 19, 2009 | 02:22 AM
Do you think my cat-back is too big?.. And yes I have heard CIA is very good!
D4u2s0t's Avatar
def too big.
vibrant sounds like a chainsaw, especially on the 2.2. It is, however, very high build quality.
Old Dec 19, 2009 | 02:24 AM
Originally Posted by D4u2s0t
def too big.
The header/dp or my cat-back? I searched for a while and I do remember you posting in another thread that it sounds like a chainsaw.
Old Dec 19, 2009 | 02:26 AM
D4u2s0t's Avatar
header/dp
Old Dec 19, 2009 | 02:32 AM
Hmm, I might check into CIA then.. I remember reading someone said anything over 2.25" for a cat-back on an NA is too much..
Old Dec 19, 2009 | 08:33 AM
oldskool's Avatar
2.5" is fine for a 2.2, especially tuned with the LE5 intake mani...
Old Dec 19, 2009 | 10:32 AM
D4u2s0t's Avatar
it's more the header size that's too big.
Old Dec 19, 2009 | 04:15 PM
What's a better choice other than the Vibrant combo?
Old Dec 19, 2009 | 04:56 PM
blackbolt89's Avatar
primaries are toooooo big for a 2.2
Old Dec 19, 2009 | 05:13 PM
olivecj's Avatar
Ok i went through this process myself with my 2.4 g5 gt. You are correct your catback is too large you need a 2.25 catback because you'll actually loose low end power. I have a clearimage header and downpipe and you can definetly feel the power increase. I went with 1.58 primary its actually the best size for the 2.2/2.4. I would suggest selling your ark catback or trade it for a gmpp 2.25 exhaust its better suited for your vehicle.
Old Dec 19, 2009 | 05:17 PM
nikebaseballx00's Avatar
do a zzp midlenghth combo
i have heard nothing but good about them
i had the obx combo on my car but it wouldnt seal, i got new gaskets and put the bolts on in the right order... i think the header was warped
but while it was on the car ripped, pulled all the way thru the powerband, i believe it was 1.5 primaries and 2.5
Old Dec 22, 2009 | 12:30 AM
I was told with a tune my cat-back will be fine. I don't know for sure though.. I like it and I'll be a stubborn bitch to get rid of it.
I'm not 100% on the quality of ZZP.. I've heard the cats blow ass on them.
Old Dec 22, 2009 | 12:46 AM
HolyJerex212's Avatar
i went with 1.7 primary header 2.5 dp and 2.25 gmpp catback...sounds great and has lots of low end pull all combined with the LE5 intake setup and you should have some decent gains similar to my own
Old Dec 22, 2009 | 01:31 AM
Yeah, I'm going to keep my ARK.. I love it too much. I just need a header/dp combo now.
I'm hellbent on the Vibrant but it's too big I guess..
Old Dec 22, 2009 | 01:36 AM
thedude411's Avatar
noooooooo... ugh i was thinking of getting that... but ive had soooo many problems with the cats on my car already. i basically want a new header/DP to get rid of the stock cats
Old Dec 22, 2009 | 01:39 PM
boltedbalt's Avatar
well not to thread jack but here's what im doing just to give ya and idea
Have....Injen CAI, 2.4L intake mani, SS header and Downpipe, custom 2.5 cat back pieced together
Soon....Trifecta, under drive pulley (possibly), springs, mounts and QTP y pipe
Old Dec 22, 2009 | 02:41 PM
evZO6's Avatar
How big are the primaries on the Vibrant?
Old Dec 22, 2009 | 06:39 PM
Maven's Avatar
big. too big for a 2.2 1.71" iirc.
Old Dec 22, 2009 | 06:42 PM
D4u2s0t's Avatar
they use magnaflow cats, pretty sure. Quality is great, i bought mine in the first group buy they ever did, and have had zero issues with it.
Old Dec 23, 2009 | 05:22 AM
oldskool's Avatar
I run the LSJ pacesetter header (1.75" primaries, 3" collector), and 2.5" pipe on my L61 cavalier - it traps 92-93 - it's not too big depending on what your goals are...
Old Dec 23, 2009 | 08:22 AM
D4u2s0t's Avatar
what else do you have done to the car?
Old Dec 23, 2009 | 01:37 PM
evZO6's Avatar
After I posted i found out that they were 45mm from their site, but that does seem a bit large for a 2.2 cobalt.
