How is this sounding so far..?
Old Dec 29, 2009 | 08:40 PM
  #76
huckernage's Avatar
Originally Posted by D4u2s0t
Are you saying that 1/8' makes no difference on the primaries? If so, you should keep out of this conversation.
show me the number that 1,625'' is better that 1,75'' primaries.
you, him and I probably wont notice a different, if we try it
Old Dec 29, 2009 | 09:24 PM
  #77
tru2nrtt777's Avatar
The dyno will.
Old Dec 29, 2009 | 09:27 PM
  #78
huckernage's Avatar
yeah, but until someone test it we can put that stand by.
Old Dec 29, 2009 | 11:44 PM
  #79
Maven's Avatar
Originally Posted by xxxxsh4d0wxxxx
TRI-Y
4-2-1
^^Both from CIA.
And on such motor, the 1 5/8" primaries are more suitable over the 1 3/4" primaries? Correct?
Yes I would definitely go 1 5/8 over 1 3/4 for your build.
The top header is a TriY or 4-2-1 design, it has 4 primaries that merge into 2 larger secondary pipes, and then into 1 collector. 4, 2, 1.....get it?
The bottom header is a single merge, or 4-1 design, that is all 4 primaries merge into the collector at once.
421 and TriY are different names for same thing.
Youll find TriYs tend to offer noticeable more torque than a 4-1(single merge) design, and more horsepower through the midrange, a 421 will give up some horsepower at the very peak to a properly designed single merge, but IMO its not enough to justify giving up the edge the 421 has down low and in the middle.
Old Dec 30, 2009 | 01:12 PM
  #80
xxxxsh4d0wxxxx's Avatar
Exactly, I read that the 4-1, will be strong up top where a TriY would have peaked already, but, I don't want all of my low end gone and have a dog off of the line and throughout the mid-range.
Now to decide.. High flow cat.. Or cat-less..
Old Dec 30, 2009 | 02:24 PM
  #81
huckernage's Avatar
if you dont care about polution cat-less
Old Dec 30, 2009 | 06:38 PM
  #82
HunterKiller89's Avatar
Originally Posted by huckernage
if you dont car about exhaust note cat-less
fixxed. lol
Old Dec 30, 2009 | 07:15 PM
  #83
D4u2s0t's Avatar
I think catless sounds like ass on these cars, not worth the extra 2hp in my opinion.
Old Dec 31, 2009 | 01:07 AM
  #84
Originally Posted by HunterKiller89
fixxed. lol
So I've heard..
Old Dec 31, 2009 | 06:13 PM
  #85
2hp? A properly designed cat doesnt restrict that much unless youre well over 350+
Remember this is a bolt on 2.2 with stock internals.
Old Jan 13, 2010 | 06:47 AM
  #86
007CobaltLS's Avatar
I'm in the same boat as the OP...kind of....
I have a Pacesetter (for the LSJ 1.75" primaries) and an Exhaust Depot catless DP. I also have a stock LSJ cat-back. All of them haven't been installed yet. I'm trying to wait a while as I only have an Injen CAI so far. My end goals are to SC the car. That's the reason I went with the size I did (plus I got a wonderful deal on it from someone here).
My question is this (I didn't read the entire thread)...what will happen with this setup? Being that it's the stock LSJ cat-back it's a little more restrictive than an aftermarket so will it perform a tad bit better than what OP 's would? Would I have any gains in any power band? My goals for right now until the car is paid off are MPG...intake, full exhaust, and a Trifecta tune. Once the car is paid off I plan to put together the SC which probably won't be until at least summer of 2011. Possibly later.
Would I be best off just waiting on installing the exhaust? Also, any opinions as to the sound of the catless DP with the stock LSJ cat-back? Would there be any benefit to just installing the cat-back without the header/dp (in terms of power or mpg)?
Thanks for any help.
Otherwise, if I pick up a Pacesetter with the smaller primaries for now, would that work OK with the catless DP and LSJ cat-back? If so, I'll try to find one pretty cheap that I can install for now and get rid of later when I get the SC setup ready to go.
Old Jan 13, 2010 | 08:37 AM
  #87
huckernage's Avatar
install everythings. dont wait.
install exhaust setup then tune it
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
