injectors
Old Aug 30, 2007 | 05:13 PM
disposable_her0's Avatar
injectors
whats the biggest injectors a stock 2.2 can handle; stock engine with a CAI, header/downpipe/catback....just wondering...please dont flame..injectors are something i know nothing about
Old Aug 30, 2007 | 06:08 PM
XM15's Avatar
You don't need new injectors with just bolt-ons. The stock ones are more than sufficient unless you go f/i
Element2.4's Avatar
X2
Old Aug 30, 2007 | 06:14 PM
Psykostevo's Avatar
As if right now the stock ones, because you cannot tune to compensate for the injectors on the 2.2L
The 2.4L and 2.0L need bigger injectors, you can still have fun with your squirtguns.
Old Sep 4, 2007 | 09:11 AM
ok thanks guys
Old Sep 4, 2007 | 09:12 AM
06blackg85ss's Avatar
got here too late. Oh well, but yeah no reason for you to swap unless you go s/c or t/c
Old Sep 4, 2007 | 09:24 AM
NJHK's Avatar
Also understand that putting on a larger injector without controlling anything will be your downfall.
Your computer is set to run at a certain duty cycle for every driving condition from idle to wide open throttle.
Think of it like this, a 24 # injector at 25% duty cycle is going to flow less fuel than a 34# injector at 25% duty cycle.
Excess fuel will cause overly rich fuel mixtures and a power LOSS.
But like everyone said, there shouldn't be a need for larger injectors.
Old Sep 4, 2007 | 12:36 PM
YellowLT's Avatar
I speak from experience when i say the Computer wont handle larger injectors.
Old Sep 4, 2007 | 02:25 PM
IonNinja's Avatar
what injectors are an option for us anyway, say if we're taking the motor up to 7Kish...I know stock injectors can't provide enough fuel for that airflow.
Old Sep 4, 2007 | 02:31 PM
NWAE Cobalt's Avatar
If you need them for an upgrade - it will let you know. Such as with the Garrett Alpha Turbo Kit - it gives you larger injectors with the kit. Otherwise...you dont need them.
Old Sep 4, 2007 | 03:56 PM
Sw4y1313's Avatar
Quick and easy would be stock ss/sc or irl injectors. they are cheap and easy to find but you would need something to tune them of course.
Old Sep 4, 2007 | 04:01 PM
NJHK's Avatar
Any Bosch style High Impedance Fuel Injector.
Old Sep 4, 2007 | 05:22 PM
IonNinja's Avatar
will any of these clip into the stock harness or do they need to be spliced in?
Old Sep 4, 2007 | 05:47 PM
06Pursuit's Avatar
bosch style should clip right in
Old Sep 4, 2007 | 06:08 PM
NJHK's Avatar
I would assume it would be just fine but I'm not 100%
Old Sep 4, 2007 | 06:43 PM
IonNinja's Avatar
cool, gotcha...
good to know when the time comes...
Old Sep 4, 2007 | 06:48 PM
YellowLT's Avatar
I have a set of Stock SSS/c Injectors Fit Leak free and Clip right in
Old Sep 4, 2007 | 09:41 PM
did they do anything performance wise or mileage wise?
Old Sep 4, 2007 | 09:43 PM
NJHK's Avatar
who are you asking this to?
Old Sep 6, 2007 | 01:56 AM
iLLmaTic3s's Avatar
there really is no need for them...u cant really even tune the 2.2 for them anyways...only need a piggy back ecu for that.
Old Sep 6, 2007 | 08:05 AM
YellowLT's Avatar
They Killed Performance The Car kept going into limp mode in Second Gear, plus i had to change my oil cause there was gas in it.
Old Sep 6, 2007 | 09:19 AM
NJHK's Avatar
That was cause you put in larger injectors and didn't change anything, correct?
Curious: what size did you go with? The 32 #?
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
