Installed Blitz DCIV Turbo Timer
Old Feb 28, 2009 | 10:42 PM
pacific cobalt's Avatar
Installed a Blitz FATT DCIV Turbo Timer today.
In case you did not read my previous HKS Turbo Timer disaster thread here's the link
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/hks-type-1-turbo-timer-question-154877/
After a huge headache with a defective HKS Type-1 Turbo Timer I was only interested in a simple 4 wire model. The speed and rpm display on the HKS were not accurate at all and I don't care much for those complicated TT's anymore.
Anyways I took it all apart AGAIN today and re-wired my new Blitz DCIV FATT Turbo Timer the exact same way. According to mrsilent13's instructions. (Big to him)
Sure enough it works fine , no problems, no C.E.L., no GM Passive Security Light. I acutually like this model better since it has a separate control unit and I don't have this huge box on top of my steering column. I decided to mount it under my cd player I think it looks best there.
There's a few extra features with this Blitz TT
- Auto Mode (Where it calculates driving time and decides how long to idle)
- Battery Voltage Display
- Interior Ambient Temperature Display (In Celsius)
- Stop Watch
- Lap Counter
- Bar Display (Ignition Pulse)
Here's some Videos
First Video I made after just have finished installing the Blitz TT. 7 hours of work later if you count the time wasted with the faulty HKS. That's why I got the Biggie Smalls on
http://s453.photobucket.com/albums/q...boTimer008.flv
Without Music. Start, Idle and 30 second countdown.
http://s453.photobucket.com/albums/q...boTimer009.flv
Night Time
http://s453.photobucket.com/albums/q...erNight004.flv
Old Feb 28, 2009 | 10:45 PM
Killa SS's Avatar
hey how did u wire to ur e brake? mine wont continue to run once i shut it off. its spliced with the ebrake but wont stay running.
Old Feb 28, 2009 | 10:52 PM
Jn2's Avatar
Jn2
cool cool glad u got it settled out
Old Feb 28, 2009 | 10:53 PM
On my Blitz TT you have the option of by-passing the whole parking brake safety feature by simply grounding the wire.
Which model TT do you have?
Old Feb 28, 2009 | 11:12 PM
Killa SS's Avatar
mine is the apexi. i tried grounding it jsut now and it will idle then just cut off. i have no idea what the H is going on. i followed the step by step. could it make a difference being mine is a clutch? and not an auto?
and by clutch i mean a standard transmission. lol
also, it being an SS/SC change the ignition wires possibly?
Old Feb 28, 2009 | 11:15 PM
My car is a manual 5 speed but mrsilent13 has an auto and he's running the apexi TT connected to the E-Brake so it should work.
If your 100% sure that all the connections are secured.
In the interior fuse panel locate the ignition fuse (There's only one that's a 2 amp fuse) check if that's not the problem.
Tell me what color wires come out of your ignition lock cylinder. I will then know if there's any difference between SS and LS
Old Feb 28, 2009 | 11:16 PM
Killa SS's Avatar
y would that fuse be the problem?
Old Mar 1, 2009 | 12:25 AM
If that fuse were blown the TT will still power up but it won't work when you take the key out. Instead it will shut off immidiately since you don't have a constant 12 v. going to the TT.
Mine was blown probably due to the faulty HKS unit I had before.
On the Ignition cylinder harness you have a constant 12v. wire. On my LS it is the Red with white stripe wire. Check to make sure there's always 12v. there even with the engine off.
Old Mar 1, 2009 | 12:41 AM
Killa SS's Avatar
ok thx. would i maybe have to put a bigger amp fuse like a 5 maybe or just swap it out?
Old Mar 1, 2009 | 12:55 AM
hungryhip-ccp's Avatar
no, dont go bigger.
Old Mar 1, 2009 | 01:50 AM
Killa SS's Avatar
ok, so any other tips? if that fuse was blown would the car still start?
Old Mar 1, 2009 | 01:38 PM
Yes I started my car with that fuse blown. My TT powered up but it did not count down when I took the key out.
If that's not the problem
Make sure you have a good chassis ground. I believe your Apexi and my Blitz both have 2 Gnd wires.
Did you solder the connections?
Old Mar 1, 2009 | 04:12 PM
Killa SS's Avatar
mine only has one ground. ill check it out today. i have it grounded right next to the e brake. where my radio is grounded. ill look for a different ground possibly.im not worried about the e brake switch for it. just as long as it works.
Old Mar 1, 2009 | 04:28 PM
Many are asking me what thread did you read that explains how to install a TT
Link to the thread where mrsilent13 explains how to wire a TT
https://www.cobaltss.net/forums/show...o+timer+wiring
Notice that he grounded his Apexi TT to the chassis right next to the Windsheild Washer Fluid Cap.
Old Mar 1, 2009 | 04:31 PM
Killa SS's Avatar
well thats not the only good ground. theres one under the hood by the intake.
Old Mar 1, 2009 | 04:42 PM
Yes there are several good grounds.
Really hope your not the owner of a defective TT like my HKS was. It's a frustrating experience especially when you know you connections are correct and you just don't understand why it doesn't work right.
I have both my grounds going to these 2 studs
Not my car in this pic BTW
Old Mar 1, 2009 | 06:15 PM
Killa SS's Avatar
well, i just checked all my connections and there all good. even when i ground the e brake wire it doesnt work. its pissing me off. ill tear the column off and check them in a min once im finished eatting. but i made sure that all those connections were correct before i put the column back together. i hope its not a defective TT.
also fuse was fine
Old Mar 1, 2009 | 06:21 PM
Mnatvyc1223's Avatar
damn, what really sux is they dont make TT harness' specific for the cobalt! all i did was connect 2 plugs into the ignition wiring and used a splice for the parking brake and voila.
and it's an HKS type 1 (new style), shitty manual wiring for the cobalts.
Old Mar 1, 2009 | 06:23 PM
Killa SS's Avatar
yea manual wiring sucks dick. you lucky ****. lol. F ur jap car.
Old Mar 1, 2009 | 07:24 PM
Videos added to first page
Old Mar 1, 2009 | 09:11 PM
i r hearts me evo, i wash it then eat sushi straight off the hood.
Supercharged06SS
Dec 11, 2022 04:47 PM
patooyee
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
maliki778
Oct 1, 2015 07:39 PM
