when I go to attach the fuel rail on the mounting brackets the injector is torqued and gets pushed out of the fuel rail then when I charge the system all 4 injectors leak from the rail side. I tried several different ways to install the injectors. as long as I don’t attach the fuel rail to the mounting bracket they don’t leak at all. Is there different mounting bracket or fuel rail I should be using.
