Installing ZZp stage two kit
Old Mar 26, 2019 | 04:22 PM
biglew's Avatar
when I go to attach the fuel rail on the mounting brackets the injector is torqued and gets pushed out of the fuel rail then when I charge the system all 4 injectors leak from the rail side. I tried several different ways to install the injectors. as long as I don’t attach the fuel rail to the mounting bracket they don’t leak at all. Is there different mounting bracket or fuel rail I should be using.
Old Mar 27, 2019 | 10:51 AM
Try with the injector connectors facing down instead of up.
Old Mar 27, 2019 | 11:17 AM
biglew's Avatar
Thanks Ill give that a try
Old Mar 28, 2019 | 04:24 PM
biglew's Avatar
worked great Thanks Slowbalt200
Old Mar 28, 2019 | 04:44 PM
Glad you got it sorted! No problem sir.
Rusty
How to Guide
36
Oct 25, 2016 10:21 AM
joshcsepegi
Jun 29, 2015 08:35 PM
SSfamilywagon
Jan 12, 2010 04:16 PM
blackss2.0
Feb 23, 2009 06:03 PM
bernandovelasquez
Feb 20, 2009 03:49 PM
