lean code
Old Dec 8, 2009 | 10:49 PM
jonxxxedge1's Avatar
lean code
so after i installed my 2.4 mani, i got a lean code. theres no vaccum leaks or anything. i took it into school today and my teacher that works at gm said that i have to get my ecm reflashed to be up to date. any truth to this? it was code p0171
upppppp
Last edited by jonxxxedge1; Dec 8, 2009 at 10:49 PM. Reason: Automerged Doublepost
Old Dec 8, 2009 | 11:06 PM
Mike85220's Avatar
I hear that some CAIs make these 2.2 10.1:1 compression engines go lean.
Having the 2.4 manifold, especially in cold weather is going to have a very good chance of going lean with the stock program.
Old Dec 8, 2009 | 11:49 PM
blackbolt89's Avatar
i had a P0171 about a month ago and it turned out that i had a tiny crack in my manifold from when i got into an accident.
i would check for cracks. we personally used a shop vac on blow, took the intake off, had someone sit on the gas pedal and blew air into the throttle body/manifold while spraying water on the intake mani.
found the crack. it was a TINY hairline crack that we puttied up with quiksteel and guess what. code went away.
i doubt it has anything to do with weather relation in that our stock ECMs can generally adjust fuel air ratio on the fly, but are generally limited in how much fuel it can give. so if its a leak it usually can't adjust the AFR correctly. just saying.
try the method i said. its simple and fairly quick. if there are no bubbles then idk. lol. i ran with CAI and 2.4 Mani in cold weather for about 2 months before getting tuned for all my mods and it was fine.
Old Dec 8, 2009 | 11:57 PM
ok im starting to think there could be a crack. cause the evap part on the manifold is a little messed up
Old Dec 9, 2009 | 04:12 PM
Mike85220's Avatar
The band-aid is coming off.
Old Dec 12, 2009 | 12:58 PM
bump need help
Old Dec 12, 2009 | 01:03 PM
Maven's Avatar
Okay you need help but what have you done?
Did the code only come on after the intake install?? That should be a clue right thur.
Old Dec 12, 2009 | 01:08 PM
it only came up after i installed the 2.4 intake mani. i took it on and off 3 times and it keeps coming up so idk what it could be. no leaks or anything
Old Dec 12, 2009 | 01:31 PM
Maven's Avatar
There pretty much has to be a leak if it only comes on with the 2.4 manifold on.
Didnt you have a brake booster hose issue?
Do you have all the proper seals for the manifold?
Old Dec 12, 2009 | 01:46 PM
06_ion2's Avatar
does it idle normal? or have a speratic idle? idle high?
Old Dec 12, 2009 | 01:52 PM
same idle and everything. the gasket is really close to the edge of the t.b. though
Old Dec 12, 2009 | 02:26 PM
06_ion2's Avatar
did you unplug the battery?
Old Dec 12, 2009 | 07:07 PM
yeah multiple times
Old Dec 13, 2009 | 10:34 AM
BLKLS's Avatar
if you got the code after the install then you have a leak. how are you checking for it? just because you can't see, or hear a leak dosen't mean you don't have a leak.
you should probly take it to a shop and have it checked.
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
