Major electrical problem...
long story short, i put the worng relay into my fuel pump relay, it was higher amp and when i went o start my car it blew/fried something.. it wont roll over now, somethings really wrong, makes a weird sound.. check vid.
http://www.youtube.com/watch?v=lm6nJOI1ikY
This is going beyond my know how, but my buddy with an ss is comming over today and were trying a dif blower on my car that he has to see if that's my issue. I can ask him about ur problems and c what he says or maybe if he can shoot ur way and help out
sure just shoot me a text.
havnt pulled the plugs. but will do, dont have a puel pressure gauge
most like you fried the junction box in the car, (or the wires going into it) With a higher amp relay something fried, you may be able to repair just the circut for the pump but it may have damaged other wires as well. Best thing to do would be to put the correct relay in, gain access to the pigtail that powers the pump and check to see if your getting power back there. if you are pumps bad. if you arent u have an electrical issue and most likely its in the junction block,
ya bro the battery looks as if its almost dead. when you tried starting it all the guages went dimmed. and it sounds like its rolling over ok, but that may just be because of the vid... a little test you could try is get another car and try jumping your car with the cables and if still no start, then its obviously not the battery. just a little test you could try.
yea, somehting else is wrong.. the battery is fine. i cant play music with the amp going... its something else.. if only the mechanic would get his ass over here already. ive been waiting since 9am.
but have you checked the battery? thats what your problem looks like. try putting a charger on it
