Motor Oil
well i just changed my oil today, took me like 20-30 mins (had to wait for the drain to stop dripping) but the car runs great and a lil quieter. i used Mobile 1 and a Fram filter. thanks for the responses guys
Originally Posted by BlueThunder2006
I've been debating this myself. I've used Castrol GTX in everything I've had, from a Z34 Lumina to my S10's. And it's always held up well. However, I've heard quite a few people (on this board, and other places) say that synthetic is best for DOHC 4-bangers like ours. Is there really any rhyme or reason to this, or does it not make that much of a difference? I change my oil and filter religiously, so oil longevity isn't really at issue. I just want to help make sure my engine lasts...
I've been using Mobil 1 in my 3100 pushrod V6 for the past 70k miles without any problems or oil burning. The only reason I lose 1/2 qt between 5k mile changes is my front crank seal is leaking.
Don't bother using synthetic if you change your oil every 3/3k. Waste of money. If you're using synth and your engine is in good running condition with no coolant leaks etc etc, you can push an oil change to 7k easy.
www.bobistheoilguy.com <- Steep learning curve but more information and educated people obsessed with oil then you could imagine.
Originally Posted by qcpursuit
just ask your dealer to put mobil one with gm filter(dealers should have mobil 1 in stock because ist the only oil that goes into the corvette)
Right now Canadian Tire has Mobil 1 4.4L plus 1L bonus for $30.
i just want to give the people here a heads up and let you in on a little secret. Wal-Mart has the cheapest oil. for 5 quarts of mobile 1 syntheic oil was only 20.17. fram filter 7.47 which makes it under 30 dollars to change your own oil. I know i used to go to autozone and get my oil there but i was paying just under 40 dollars for everthing like oil and filter. So enjoy
ryan
ryan
Be careful when taking it to the dealership. I took my SS/SC in to have the oil changed and I took in my own oil (cheaper). When they finished I checked the oil before I left and sure enough they only put 5 qts in when it requires 6. They tried to tell me I only brought 5 qts and that it only took 5. After a long dispute they put in the 6th qt. and gave me a coupon for a free oil change which I will NOT be using.
castrol=higher oil pressure and something like 2hp gain over mobil 1
mobil 1=super protection,easy cold start and great overal performance
torco=high pressure oil but a little bit less than castrol
motul=low pressure oil good for forced induction
Originally Posted by Malaclypse
Normally it makes me cringe when people use Fram filters due to their canister filter's internal construction. However, since the Ecotec has a permanent canister and removable element... those problems are no more.
I use a K&N for my air filter and a Napa or Delco filter for the oil (advantages of having a dad that works for Napa and a brother who works at a Chevy dealership)
Oh and for oil, I went the el cheapo route since I plan on trading in a year or so and run nothing bu valvoline 10W30/10W40...
Scott
Im surprised nobody on here has listed Bosch fliters. I run Mobil 1 and a bosch filter all the way baby. And you can definitly notice a difference in starts, idleing smoother ect with synthetic over regular motor oil...
ThoR294
Oct 4, 2015 08:44 PM
