MRZ pulley review
Old Sep 21, 2008 | 12:08 AM
  #51
Maven's Avatar
Originally Posted by originaladrian
well at least find somewhere after the alt lol, wont really make a difference if its before.
Where exactly would "after" and "before" the alternator be?
And why is it bad to test directly at the battery?
Originally Posted by Section8cav
reving quicker is the Primary gain you get.
you will NOT get much if any hp gain from a pulley..i think JN2's Dyno charts prove that point.....a 0.7hp gain from stock?..and i called this before it was even dynoed.
now using the pulley in conjunction with a light flywheel,lighter rims,lighter crank, etc.
then it starts adding up and real gains are seen...but taking 3lbs off the crank pulley isnt gonna make much difference alone.
Actually, I see that he gained 2.8hp with the lightweight, and 3.5hp with the UDP.
Revving quicker=more horspeower, btw.
Old Sep 21, 2008 | 12:41 AM
  #52
theneelster's Avatar
revving quicker means you GET to your power quicker. Add this and a lightweight flywheel and you'll be stalling out like a madman especially on hills.
Old Sep 21, 2008 | 01:28 AM
  #53
Maven's Avatar
No, revving quicker means you do the same amount of work in less time, in other words youve got more horsepower.
Old Sep 21, 2008 | 02:40 AM
  #54
copson20's Avatar
JN2 why are your Hourse power and Torque #'s so low i thought you had a tune and stuff?
Old Sep 21, 2008 | 03:28 AM
  #55
Jn2's Avatar
Jn2
im not tuned...all i have is intake, and full exhaust as power mods, the rest are traction or looks mods...and than the pulley lol...im saving to get the RK lipkit, than stg1 cams, than a tune and i will have higher numbers, until than, those r my #'s, 1/4 mile i run mid 15's
mods if you see this, hurry and approve my how to as i need to go back and spell check my ****, and add new info and what not
Old Sep 21, 2008 | 12:03 PM
  #56
Section8cav's Avatar
im not gonna argue with someone who cant even read..he LOST hp with the lightweight,not gained,
his STOCK pulley ran him 127hp ..the oem sized lightweight got 124 and the UD pulley got 128....
Old Sep 21, 2008 | 12:06 PM
  #57
Jn2's Avatar
Jn2
the 124 run might of been heatsoaked , we did a warm up run, than 2 pulls...the udp did add some thru out the all rpms compared to stock
Old Sep 21, 2008 | 12:13 PM
  #58
and it very well could have been..looks like it did give alittle more thru the range than the others as well, which can be expected.....btw what rpm are you shifting at on on the track?
Old Sep 21, 2008 | 12:35 PM
  #59
Jn2's Avatar
Jn2
track i shift at 6500, i start the throw at 6300 to avoid bouncing off the lmiter
Old Sep 21, 2008 | 12:48 PM
  #60
rockstar014's Avatar
sweeett im happy
Old Sep 21, 2008 | 12:49 PM
  #61
Red07SSNA's Avatar
Not trying to start an argument....have you considered shifting at 5500-6000 RPM? Your dyno charts show that the engine is beginning to drop HP and torque by 5300 RPM. If you run on a track I'd bet money that you will actually reduce your ET by shifting at 5500 RPM rather then 6500 RPM.
  #62
Jn2's Avatar
Jn2
been taling it over with section8 ima try shifting at those points, even though i know i will be forced to shift into 4rth, which will kill some time aswell
Old Sep 21, 2008 | 12:53 PM
  #63
Jn2's Avatar
Jn2
eh its worth a shot
Old Sep 21, 2008 | 12:54 PM
  #64
Red07SSNA's Avatar
Try it, you may find your MPH is down but your ET is lower. Sounds crazy but it may just work.... My auto shifts at 6700 but I'd like to get it to shift earlier...no need to make the engine sound like a sewing machine before shifting. Listen to a dragster going down the track...they don't wind out the engine, they shift just after peak HP is made.
Old Sep 21, 2008 | 01:08 PM
  #65
Jn2's Avatar
Jn2
worth a try, it wont hurt any, not like im going to the track to test just that out, lol
Old Sep 21, 2008 | 02:43 PM
  #66
originaladrian's Avatar
pshhh my car dosnt even feel like it makes any power below 4k
Old Sep 21, 2008 | 02:56 PM
  #67
CobaltLs_14's Avatar
no power under 4k? what do u have 2.0, 2.2, 2.4 and what are u running (mods)?
Old Sep 21, 2008 | 03:05 PM
  #68
Jn2's Avatar
Jn2
PE doest kick till about 4k-ish, most likely the PE delay ur feeling, or not feeling, w/e, but low end is all these damn cars have, anything after 5 starts dying on the 2.2
Old Sep 22, 2008 | 02:27 AM
  #69
Jn2's Avatar
Jn2
how to has been submitted, unno when the mods will approve of it, since i posted it a whle ago and it hasnt been approved to add more info to it,i made another including pics, vids of idle inside and outside the car,along with turning the a/c on
Old Sep 22, 2008 | 10:12 AM
  #70
jpunishment's Avatar
i got my fastest quarter mile time shifting at 6 grand when i was stock i havent tried it yet with my current mods but after i installed the 2.4 manifold and dynoed , my dyno sheets were showing a making power all the way thru the power band it doesnt fall off like it did when i dynoed stock
Old Sep 22, 2008 | 10:29 AM
  #71
ChevyRockstar's Avatar
nice review
Old Sep 22, 2008 | 10:35 AM
  #72
subscribed
Old Sep 22, 2008 | 01:38 PM
  #73
IonNinja's Avatar
where it says "stock" is that stock sized lightweight pulley or OEM pulley? I can't read whatever the hell you wrote in the 2nd dyno
and would you guys please stop arguing about this. you're nitpicking over wording, you're all saying the same damn thing.
Old Sep 22, 2008 | 03:54 PM
  #74
well considering theres a PIC of the lightweight OEM size pulley and it says" heres my lightweight OEM size pulley: over it...
Old Sep 22, 2008 | 05:34 PM
  #75
IonNinja's Avatar
i see no such thing
