New plugs
Old Aug 10, 2009 | 02:28 PM
xxxxsh4d0wxxxx's Avatar
New plugs
ACDelco Spark Plug
Part No. 41-103
IRIDIUM; @ GAP .043 @
I believe these are the stock plugs, I found them at advanced auto because my dealer wanted $12 each. I was told between .044 and .040 gap is good for these cars?
Old Aug 10, 2009 | 02:52 PM
jonxxxedge1's Avatar
the stock ones for the 2.2 are garbage. i burnt mine out within 15,000 miles of having them
Old Aug 10, 2009 | 03:00 PM
Yeah man, I'm on 17,200 miles and I'm having problems. The car like misses a fire at idle and you can feel it. I feel like I've lost power too. It must be the plugs.
Old Aug 11, 2009 | 05:25 PM
icarus4586's Avatar
That's weird. I took a look at my stock plugs at about 35,000 miles and they looked pretty much good as new.
Old Aug 11, 2009 | 05:52 PM
lwpmoon's Avatar
Mine were doing ok at around 30k... till I turboed it. Ya... they didn't like that I switched to NGK's 1 step colder.
And yes .044" is good
Old Aug 11, 2009 | 05:55 PM
roser4888's Avatar
Gm stock plugs are good for 100000 miles
Old Aug 13, 2009 | 03:31 AM
Z-Bolt's Avatar
I heard this too, and do believe it somewhat except for the fact cylinders 2 and 4 didn't have any planinum left on the plugs and 1 and 4 showed significant wear at under 76000 miles
Old Aug 13, 2009 | 03:36 PM
weiss27md's Avatar
Any recommendations on replacement plugs for a NA 2.2? and maybe a link?
Old Aug 14, 2009 | 03:59 AM
Z-Bolt's Avatar
I went to the Bosch Platinum+4, they were the same price as the Delco OEM plugs. Here is a link to the manufacturer's Web site. The A/C Delco's were 5.50 a piece and the Platinum+4 were the same price. Didn't make since to pay the same amount for something less. Even though the OEM plugs are platinum, the Platinum+4 are "claimed" to be more. I noticed a better response, milage, and overall start up with new plugs; you should find this to be true regardless of plug type but I "think" the Platinum+4 for the money is the better buy. Bosch makes one step up, in quality and better spark performance without going to a multispark device, from this and they were around 7.50 per plug, the Bosch Platinum Ir Fusion.
Old Aug 15, 2009 | 01:20 AM
Dimitri Manesis's Avatar
Has anyone tried M-3 plugs???
Dimitri
Old Aug 15, 2009 | 01:56 AM
Maven's Avatar
NGK/ACDelco or Denso are what I almost always use in every ECO I work. You dont adjust gap on iridium plugs, if the gap isnt set right out of box the plug is damaged, ACD plugs have a plastic protective sleeve on them. +4s are gargbage, I wouldnt run a multi-electrode plug in my car, ever.
Old Aug 15, 2009 | 11:48 AM
Jn2's Avatar
Jn2
QFT the bosch are trash, stick to stocks unless ur boosted, they are drop in out of the box...no gapping required
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
