no more chirp ??
Old Nov 24, 2008 | 04:32 PM
ilovecars's Avatar
no more chirp ??
so i used to chirp when ever i slammed it into 2nd but now when i do it no chirp is it cuz im ******* the **** out of my clutch or what? thats all i could think of the case would be.
Old Nov 24, 2008 | 04:37 PM
Nato09's Avatar
new tires.
Old Nov 24, 2008 | 04:38 PM
invisible's Avatar
Clutch is slipping.
JRelly's Avatar
Originally Posted by Nato09
new tires.
x2
vB00STw's Avatar
Stop pussyfootin' around and slam that thing harder!
Old Nov 24, 2008 | 04:39 PM
D4u2s0t's Avatar
well is the clutch slipping when you shift?
Old Nov 24, 2008 | 04:41 PM
INDColtsFan18's Avatar
did u make any modifications?
Old Nov 24, 2008 | 04:49 PM
ilovecars's Avatar
yes i did make mods header, dp, exhaust thats all preformance wise. my tires arent new. im slamming that **** as fast and as hard as i can but it wont do it lol
Old Nov 24, 2008 | 04:51 PM
chris88z24's Avatar
Depends on tires and road conditions.
Old Nov 24, 2008 | 04:52 PM
leahciM's Avatar
it's cold out now......... no chirp. (But seriously... is it cold out where you are?)
Old Nov 24, 2008 | 04:53 PM
ilovecars's Avatar
hmmm cold road warm tires?
Old Nov 24, 2008 | 04:54 PM
leahciM's Avatar
well i know for a fact my tires won't chirp when it gets cold out.. but i'm in canada so it's a different story up here... but I'll brb the candle just went out in my igloo
Old Nov 24, 2008 | 04:55 PM
invisible's Avatar
Clutch. You can't shift like that and not expect to slip. It's just gonna keep getting worse if you keep doing it.
Do you have cable tv yet?
ilovecars's Avatar
lol.
but only after 3k miles? and its not like i do it every start.
Old Nov 24, 2008 | 04:56 PM
Blackout06LS's Avatar
Weather conditions, road, tire temp
cold cold cold do not chirp
Which is why I don't do this anymore.
Last edited by Blackout06LS; Nov 24, 2008 at 04:56 PM. Reason: Automerged Doublepost
Old Nov 24, 2008 | 05:01 PM
JRelly's Avatar
We were saying you need new tires
Old Nov 24, 2008 | 05:07 PM
ilovecars's Avatar
nope pretty dam good tread on these. you saying less tread grips better?
Old Nov 24, 2008 | 05:12 PM
JRelly's Avatar
What tires are you running? Less tread does grip better from a launch thats why people use slicks but they wont chirp when shifting.
Old Nov 24, 2008 | 05:14 PM
ilovecars's Avatar
stockers lol there low rolling restance a/s shitty tires. and i see. but i dont think my treads worn down that much only have like 3k miles
Bika's Avatar
Fail Less.
on smooth, dry surfaces, smooth tires do grip better. more surface area contacting the ground.
Thats why track cars almost always use slicks or drag radials.
Old Nov 24, 2008 | 05:26 PM
ilovecars's Avatar
hmm. i guess i just need to slap a supercharger on it then ill chirp
Old Nov 24, 2008 | 06:10 PM
Maven's Avatar
Yo, if you cant spin the tires in second anymore youve got an issue....... Regardless of whether its cold or hot, wet or dry, your car should chirp the tires on a fast 1-2 shift, it may not make the same noise....but it should still spin them the same, you should still feel the same hop/shudder as when they make lots of noise.
Old Nov 24, 2008 | 06:15 PM
HackAbuse's Avatar
I chirp fourth at full throttle
Old Nov 24, 2008 | 06:43 PM
Sometimes mods like intake and exhaust will acuse you to lose a little bottom end power but you will gain more in the top end. When i put on my intake i noticed a little shorter of a chirp, it still did it though.
Old Nov 24, 2008 | 06:53 PM
D4u2s0t's Avatar
depending on the size of your exhaust you may have shifted your powerband up higher in the rpm range, and that could be the reason why you're not chirping anymore.
