ottp longtube issues
hey, so im installing my ottp long tube header, and cant get the freakin o2 sensors in, their is just not enough room between the bung and the heatshild/firewall, i even tried bending the heat shield out of the way, and help or ideas? im stuck, is their a shorter o2 sensor i can buy?
sucks. I thought they had changed the positioning it was bad before and I pointed that out. try removing the header, and pre installing the 02 sensors then re installing the header.
i'm thinking i might have to do that even tried dropping the engine down a bit, sucks was a pain to get all the bolts for the header on the block in the first place.
