Personal service thread - motovation
Old Sep 12, 2013 | 09:47 AM
05g5's Avatar
Just a personal thing, to keep me motivated. and keep track.
because none of my vehicles are NEVER 100% the way i want them. Always a work in progress. I ride this car hard, so I have to keep up with ****.
If you guys got advice, anything thing that can help. Post up !
Also any leads or links to new/used headlights and exhaust is nice.
Work that needs to get done
End links and lower ball joints ( suspected of alot of my front end issues im having )
THIS weekend hopefully
Rear defog doesnt work.
All fuses and relays work fine, suspect a broken wire somewhere. Probably going to re-wire it. Just splice and replace front to back.
Exhaust leak
Will hopefully get after market header/down pipe - stock header i believe is leaking
New Front headlights ( or new used )
Tint new headlights
Front breaks grind
2 month old pads, suspect rotors possibly? or i bent something during the job. No obvious signs of wear, have to look deeper.
Rear break shoes
Take the time to get those rear **** drums off. Tried once, drunk for 5 minutes - gave up.
2 New front winter tires
Power locks
Dont work from inside the car, the remote works them fine...
Shifter lights
my girlfriend says they used to work.. I dont remember, but not working none the less
Body work
Paint chips around all wheel wells & entire car for that matter, cracked rear bumper, paint?
Might not ever do this, but it would be nice.
Driver site strut - maybe
previous owner replaced passanger side after hitting a curb and blowing it
Work done
Fuel Filter
Ail filter
Spark plugs
Throttle body taken off and cleaned
Remove resinator
Tranny pan
Tranny Filter + fluid
Driver side wheel bearing
Timming chain tensioner
Blower motor + resistor
Smoke rear tail lights + bulb replacement
Front break Pads
Other things like : motor oil flush, injector cleaner, ETC
Other things done by previous owner
Passanger side strut
tint windows
magnaflow muffler
stereo system
others, unknown
Old Sep 14, 2013 | 12:52 PM
05g5's Avatar
End links done. Was definatly my problem, loose as fawk and make noise
Ball joints another day
Old Sep 17, 2013 | 01:23 AM
scagnetti76's Avatar
I flush brake fluid every 30k, and coolant at 50-60k. Change oil at 25-30% life, changed manual trans fluid at 50k, plugs at 60k, lube SS endlinks every tire rotation. At 77K MY L61 still runs like a champ...
Old Sep 17, 2013 | 01:41 AM
Wired's Avatar
Shifter light bulb is easy. Just pull apart the center console trim and shifter.
Thread here: https://www.cobaltss.net/forums/how-...matics-178638/
Also gives the bulb number.
Old Dec 5, 2013 | 12:25 PM
05g5's Avatar
Exhaust leak
Tint new headlights
Front breaks grind
Rear break shoes
Power locks
Shifter lights
Body work
Work done
Fuel Filter
Ail filter
Spark plugs
Remove resinator
Tranny pan
Front break Pads
tint windows
magnaflow muffler
stereo system
others, unknown
Add on to : work done
Headgasket got replaced. Motor cleaned , gaskets all the way around ( i dont feel bad about dumping more money into her after this. Inside that motor was in good shape + its all cleaned now )
Water pump and t-stat
Cat gutted
New wipers
A few bulbs
End links
Exhaust leak fixed, new one aroused - **** me off
Top of my to-do list
Rear defog
Driver side strut
Really wanting to do body work and touch ups
2 new winter tires
Then the small stuff and header / dp
New humming noise, suspect its the meaty winter tires i switched to the front, noise was never there before
Annnd buy some used headlights to customize. This will happen when i can find a used set for $80 and under
Late update on my part, most was done awhile ago, some recently. Just like keepig it organized
Old Dec 17, 2013 | 05:58 PM
05g5's Avatar
Bank 1 o2 sensor replaced
Now the only code i get is p0420, reminding me my cat is not there
Broke my stock antenna, so ordering a shorty ASAP
Old Apr 2, 2014 | 10:09 AM
05g5's Avatar
Kind of in order i want them done
Ignition recall.
As soon as parts arrive shes going in.
Hids
Very soon
Compete overhaul comming summer time. FE5 struts, rear FE5 shocks, FE5 lower control arms with ball joints, bushing. End links will also be needed. Rear break shoes at the same time NEEDED
Wipers
Bought some, didnt last 2 months in our harsh ass winter
Rims
Been on the look out for factory aluminum 4x100 rims. PITA
steering rack
worse then ever, fix or forget? Its been done by previous owner too.
Body work
Paint chips around all wheel wells & entire car for that matter, paint?
Speakers
Would be nice to get new speakers all the way around to go with the subs.
Power locks
Dont work from inside the car, the remote works them fine... Tried looking into it, suspect a faulty lock switch.
Shifter lights
Side note : Burns oil
But what gm economy car with 200k + kms doesnt? fawk it.
Work done
Roughly 45k Kms put on since i bought it.
Fuel Filter
Ail filter
Spark plugs
Tranny pan
Front break Pads
End Links
Bank 1 o2 sensor
Water Pump
Thermostat
Wipers
Intake/exhaust manifold gaskets
Shorty Antenna
Depo Headlights
Add Cherry bomb before muffler - NO MORE EXHAUST LEAKS - Best shes ever sounded is now
Some body work, more to come
Motor Flush
Rad Flush
Seat covers. The interior was lookin nasty lol, terrible beige interior choice GM !
Electrical problems came up, found corroded out wires under the driver seat. fixed ofc
Window came off tracks, took that apart
Other small things
tint windows
magnaflow muffler
stereo system - subs/amp/deck
others, unknown
thats lots of love for a base model lol. no wonder my girlfriend gives me **** sometimes. oh well, i love this car
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 21, 2015 11:57 PM
patooyee
Oct 15, 2015 05:11 PM
importkiller
Sep 30, 2015 07:18 PM
grampss
Sep 27, 2015 08:51 PM
