Pistons???!
Old Jun 21, 2010 | 06:00 PM
Zero6LS's Avatar
Pistons???!
I wanna buy new pistons for my L61 bcuz im putting a LNF turbo onto my 2.2L. Does anyone have ideas or suggestions about what manufacturer to buy from and what compression ratio to go with? My goal is to boost more than 12lbs and I believe I need new internals to do so. According to ZZPerformance I can boost up to 12lbs on tock internals but need to reinforce the motor if wanna boost more. Any help would be great. Thanks
Jimmy
Old Jun 21, 2010 | 06:02 PM
TurboTechRacing's Avatar
We carry Wiseco for the 2.2L, it has been the longest manufactured aftermarket piston for the ecotec. Our customers have been using them for over 10 years.
Old Jun 21, 2010 | 06:17 PM
Zero6LS's Avatar
ok thanks. ill check em out. this build is driving me broke, i wont be done as soon as i would like...
Old Jun 22, 2010 | 03:10 PM
Spanky's Monkey's Avatar
so aaron what's the compression on the cometic 87mm .50 and a set of straight stock wisecos?
what i mean is there a benefit to the thicker gasket?
Old Jun 22, 2010 | 04:39 PM
joshc.'s Avatar
Thicker gasket would drop compression slightly.
Old Jun 22, 2010 | 05:35 PM
BlackCobalt707's Avatar
if youre gonna do pistons, might as well do rods as well. rods will most likely go first before the pistons will. im currently runnin a JE piston setup with stock 10:1 compression and Eagle H-Beam rods, with ARP head studs, 3 layer head gasket and i was throwing 18 psi from a gt3076r with no problem...of course i have meth tho to keep it cool. but thats just my 2 cents of my block setup
Old Jun 22, 2010 | 09:52 PM
SmackinJuice's Avatar
The rods go because of the pistons
Old Jun 22, 2010 | 09:55 PM
Stock is about .040", .010" wont lower your compression much, i doubt it will even lower .1
Old Jun 22, 2010 | 11:18 PM
thanks, for the quick reply
Old Jun 23, 2010 | 12:10 PM
Zero6LS's Avatar
so i should get pistons and rods. thanks guys
Old Jun 23, 2010 | 12:11 PM
A good build would be pistons, rods, cometic gasket, and ARP studs
Old Jun 23, 2010 | 01:14 PM
Zero6LS's Avatar
ive got a new head gasket from CED if thats what you mean. ill prolly order some new pistons and rods when i have the money. I just bought new valve springs so I gott save some money for anything else
Old Jun 23, 2010 | 10:57 PM
that build right there will be able to hold a good amount of power
Old Jun 24, 2010 | 01:09 AM
joshc.'s Avatar
You can run the K04 on the stock bottom end just fine the L61 shouldn't put down numbers anywhere near what the LNF guys do with it, my guess would be around 220. At that power a well maintained engine will be fine for awhile. They say 250 is the limit of the rods but I've yet to see a rod go pistons usually go first and they can go at any power level(I cracked a ringland N/A).
Once the rods and pistons are upgraded you good till about 400hp and then you have to worry about cyclinder walls themselves.
Old Jun 24, 2010 | 01:32 AM
ecot3c inside's Avatar
haha! you guys own cobalts!
Old Jun 24, 2010 | 02:12 AM
Hart's Avatar
Haha what a bunch of nerds hey cobalts are for vaginas hairy ones if that
Old Jun 24, 2010 | 10:11 AM
Jn2's Avatar
Jn2
stop posting my plans for everyone to see :p
Old Jun 24, 2010 | 10:45 AM
I beat you to it lol
hhrfreek
Jun 4, 2016 11:25 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
