Problem with installation
Old Jan 23, 2011 | 05:03 PM
hugemurph4's Avatar
ok well i installed my new coil pack and ICM and the car start up fine but the car is idling rough kinda like a WRX...what the hell is going on...anybody have any ideas i need help guys...i just dropped 300 bucks on these parts and its not running right.
Old Jan 23, 2011 | 11:05 PM
07Coupe's Avatar
Sounds like its running on only 3 cylinders. I've heard a lot of honda's that were only on 3 cylinders and it sounded just like a WRX. Might check wiring. Other than that I don't know.
Old Jan 23, 2011 | 11:46 PM
lwpmoon's Avatar
I agree ^^^, I assume its down on power?
Old Jan 24, 2011 | 12:20 AM
Do_WorkSS's Avatar
fouled spark plug bro. happened to me a couple times. just repalce the spark plugs and you'll be fine
Old Jan 24, 2011 | 12:46 AM
juice3's Avatar
sub'd I'm having a similar issue.
Old Jan 24, 2011 | 02:51 AM
YelloEye's Avatar
^x2 sounds like a dead plug.
Old Jan 24, 2011 | 11:27 PM
hugemurph4's Avatar
replaced all of the plugs and still nothing
Old Jan 24, 2011 | 11:31 PM
YelloEye's Avatar
Clogged injector?
EDIT: Actually wait, are you sure all cylinders are getting spark?
Old Jan 26, 2011 | 03:56 PM
hugemurph4's Avatar
Clogged injector?
Yea i was electricuted 4 times haha what i did was i took the coilpack off and just put my finger on each boot spring as my friend turned the car over...i just dont understand what is wrong...
Old Jan 26, 2011 | 05:11 PM
Do_WorkSS's Avatar
thats a good way to give yourself a ****** defibrillator test bro...
Old Jan 26, 2011 | 10:59 PM
YelloEye's Avatar
I cannot believe you did that willingly.
Plug the spark plugs into the coilpack and set it on top of the head so they are grounded, then crank it again to see if you are getting actual spark.
Old Jan 26, 2011 | 11:03 PM
army_greywolf's Avatar
i should remind you that the packs DO produce enough amperage at 40K or so volts to stop your heart in just the right circumstance. They aren't like tasers with dual voltage, these things will kick you with 40K volts until your down.
Old Jan 27, 2011 | 11:38 AM
BigRyanJackson's Avatar
maybe the coil pack you bought is bad. gm has alot of **** products. im a tech at a chevy dealer here in jersey and i wait for a part to come in for a customers car and sometimes the part is bad.
turbochargedss2012
Sep 20, 2023 12:17 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
