Question about dual pass endplates
Old Mar 30, 2011 | 09:44 AM
  #101
BlilBT's Avatar
Yeah bought it used for my supercharger build. I'm gonna rearrange the cores according to the diagram on ccf. Also can someone tell me if this is correct for my plumbing setup. The outer lines of the endplate go to a Y then to the filler neck, then the filler neck flows to the heat exchanger input and somewhere in that line put a T fitting for my option B tank. Then the heat exchanger flows to the pump then pump to the single input of the endplate. That correct?
If using option B the Filler neck is no longer needed, the T goes where the filler neck use to be! Then the new tank 3/4 inch line goes to the long end of the T
Old Mar 30, 2011 | 09:52 AM
  #102
nizzle's Avatar
nothing showed up in that link
download it. it's a dual pass install instruction manual
Old Mar 30, 2011 | 12:21 PM
  #103
redcobalt07's Avatar
Alright, thank you. What should these cores smell like?
Old Mar 30, 2011 | 12:50 PM
  #104
nizzle's Avatar
coolant
Old Mar 30, 2011 | 01:18 PM
  #105
What if they smell like oil?
Old Mar 30, 2011 | 02:37 PM
  #106
Tennpenn83's Avatar
oil goes nowhere near that intercooler system. if yours smells like oil, you've got something terribly wrong.
it is possible that your pcv system put some excess blowby in the intake tube which caused it to deposit on the laminova cores, but that is about it
Old Mar 30, 2011 | 03:06 PM
  #107
Ok, my sense of smell must be off then. The stuff that was dripping out wasn't oil, it just smelled like oil. Hopefully I'll be able to get my IAT's down now since my stock core setup was just terribly wrong.
Old Mar 30, 2011 | 05:22 PM
  #108
IonNinja's Avatar
So does the intake manifold need to be removed in order to swap the cores and install the endplate? Doesn't look like it
Old Mar 30, 2011 | 05:28 PM
  #109
05Slowline's Avatar
Pcv don't smell like oil at all an yes u need to take the mani off to do dual pass
Old Mar 30, 2011 | 06:50 PM
  #110
Tennpenn83's Avatar
yes you do. the oil filter housing will be in the way if you don't. there really is no way to do it in the car.
how's it going man? haven't seen you around for a couple years...
Old Mar 30, 2011 | 07:28 PM
  #111
Got everything to do a dual pass but my drill battery died while working on it so I'll finish putting in the new bung tomorrow. But the first place the output of the ic pump should go to the middle spot on the endplate right? then both outputs to a Y line to the filler spot/option B tank then to the h/e and back to the pump?
Old Mar 30, 2011 | 10:03 PM
  #112
IonNinja's Avatar
ah okay it looked like you might be able to get the endplate off but I guess it would be pretty hard to pull the cores out with the filter housing there
yeah I've been MIA because my car has been a POS the past couple years in the process of getting it re-tuned right now so everything is lookin good at the moment
Old Mar 31, 2011 | 06:59 AM
  #113
Tennpenn83's Avatar
ah i remember when all you had was a helluva shot of nitrous... best of luck to you and your car man. dont be a stranger!
Old Mar 31, 2011 | 08:11 AM
  #114
Does anyone know the bolt size of the bolts around the ic pump?
Old Mar 31, 2011 | 09:32 AM
  #115
Tennpenn83's Avatar
why are you taking the ic pump off?
it's a 13 if i remember right, but is it too hard to just take a couple sockets down there to see? everything is metric on this car, so that eliminates 1/2 of the sockets already.
i'm not trying to be an ass here, but this car is not that hard to work on. you should be able to figure some stuff like this out on your own. if you can't figure out what size socket goes on a bolt, maybe you should take your car to someone else to work on
Old Mar 31, 2011 | 07:13 PM
  #116
05Slowline's Avatar
hey guys, im gonna take my wheels off. any idea what size the lugs are, i don't wanna strain myself to have to try different sockets for 5 seconds to see which one fits.
Old Mar 31, 2011 | 07:14 PM
  #117
nizzle's Avatar
U R jk right? I think they are 19mm.
Old Mar 31, 2011 | 07:29 PM
  #118
05Slowline's Avatar
yes just making fun of the 12 yr old
Old Mar 31, 2011 | 10:34 PM
  #119
I got the intake manifold off. Just be happy at being helpful, no need to a be a dick. And I'm taking the IC pump off to see if it's working or not.
Old Apr 1, 2011 | 06:36 AM
  #120
Tennpenn83's Avatar
hey bud, i've done nothing but try to help since i saw this thread. i'm just pointing out that some obvious questions that you posted on here would have literally taken you less time to solve while under the car than the time it took you to make a post
Old Apr 1, 2011 | 07:45 AM
  #121
05Slowline's Avatar
If you have to ask sizes of obvious socket bolts you really shouldn't be working on a car. If I asked every bolt size tearing down my car I would spend more time asking such foolish questions instead of working on it plus it makes you look lazy and retarded
Old Apr 1, 2011 | 10:08 AM
  #122
How is that a bad thing to ask bolt sizes? It beats guessing while its freezing outside working underneath a car.
Old Apr 1, 2011 | 10:16 AM
  #123
Tennpenn83's Avatar
go down with a few sockets, pick which one fits best... it takes less time than opening up css.net and making a post.
now, if you were asking about something a little more technical, i could understand, but this is bullshit
Old Apr 1, 2011 | 05:57 PM
  #124
05Slowline's Avatar
Omg cry me a river you act like you're the only one who works on their **** I'm the cold I've been doing it since it was 20 degrees out you don't see me asking questions that my ******* mother could figure out in 30 seconds Lmfao
Exactly lol
Old Apr 1, 2011 | 06:37 PM
  #125
Ok well, anyway. Got the IC pump off. Works. Tapped a hole into the endplate for a dual pass. Fitted a brass 90 elbow in it. I'm going to have it welded onto the endplate just to guarantee no leaks.
