Question about dual pass endplates
it doesn't even take that much, man. if you turn your key, not even starting the motor, but just turn your key, your pump will turn on after 10 seconds. that's on a stock tune.
on any aftermarket/custom tune, you can set it to turn on as soon as you key on. no need to test power from the ecu. let's try that instead.
if for any reason it doesn't turn on as described, it's likely you have a dead ic pump
theres only 1 bottom bolt, it's an 15 mm (i think) and it's easiest to get to coming from the passenger side towards the drivers side. sometimes it's just easier to remove the alternator, to see and access it easier, but i have gotten used to doing it without removing the alternator
yeah take the alternator and dipstick off, stick a deep socket down with an extension.
i left my bottom bolt on a lil loose when i did my dual pass, took my im off for good a lil ago, couldn't find the bolt
In other words, they didn't trust the assembly line workers to not screw it up and also probably didn't want to pay the extra money for the extra plumbing.
Plus anyways, they could make more money by selling the GM performance Dual Pass endplate and Option B parts for their usual "rape yo ass w/o lube" price.
Also there is a bolt in the left side of the IM that took me forever to find. If you are looking at the motor it's on the left and kinda hidden. Did you get that bolt out yet?
No the intake manifold is what I can't get off. I have the top bolts off but can't seem to get the bottom one out. I got the alternator bolts out so I'll remove that tomorrow and hopefully I can get that last bastard bolt then. Also just ordered an Option B kit and am going to remove the IC pump tomorrow to see if it works or not.
