Question about dual pass endplates
Old Mar 21, 2011 | 06:36 PM
  #51
nizzle's Avatar
Originally Posted by Tennpenn83
it doesn't even take that much, man. if you turn your key, not even starting the motor, but just turn your key, your pump will turn on after 10 seconds. that's on a stock tune.
on any aftermarket/custom tune, you can set it to turn on as soon as you key on. no need to test power from the ecu. let's try that instead.
if for any reason it doesn't turn on as described, it's likely you have a dead ic pump
I've done that. about 5 times just today and I dont hear anything. If my pump is dead, wouldnt my IAT's go sky high when jamming on it?
Old Mar 21, 2011 | 06:40 PM
  #52
Tennpenn83's Avatar
then by all means, power test it... since you're obviously one up on everybody else on these forums
Old Mar 21, 2011 | 06:44 PM
  #53
redcobalt07's Avatar
My IAT's are usually always 125-130, cold or hot outside, doesn't matter.
Old Mar 21, 2011 | 08:32 PM
  #54
05Slowline's Avatar
you don't friggin hear it the only thing you can hear is your fuel rail getting pressure
Old Mar 21, 2011 | 08:35 PM
  #55
nizzle's Avatar
thanks for the info but I cant hear it or feel anything by touch the hose either. Pump might be shot already
Old Mar 21, 2011 | 08:38 PM
  #56
05Slowline's Avatar
wouldn't doubt it if its the og pump lol
Old Mar 21, 2011 | 08:45 PM
  #57
nizzle's Avatar
it's not, just replaced it about a month ago.
Old Mar 21, 2011 | 09:18 PM
  #58
05Slowline's Avatar
shouldn't be bad then, if it was a new pump
Old Mar 21, 2011 | 09:45 PM
  #59
nizzle's Avatar
maybe not but I am just gonna replace one hose with clear hose so I can see if it is flowing or not.
Old Mar 26, 2011 | 11:42 AM
  #60
Anyone know where the bottom bolts are for the LSJ intake manifold?
Old Mar 26, 2011 | 12:56 PM
  #61
Tennpenn83's Avatar
theres only 1 bottom bolt, it's an 15 mm (i think) and it's easiest to get to coming from the passenger side towards the drivers side. sometimes it's just easier to remove the alternator, to see and access it easier, but i have gotten used to doing it without removing the alternator
Old Mar 26, 2011 | 10:35 PM
  #62
05Slowline's Avatar
yeah take the alternator and dipstick off, stick a deep socket down with an extension.
i left my bottom bolt on a lil loose when i did my dual pass, took my im off for good a lil ago, couldn't find the bolt
Old Mar 26, 2011 | 11:43 PM
  #63
Well I need my whole intake manifold off. So it's one bolt. 15mm. And the alternator has 3 bolts correct?
Old Mar 26, 2011 | 11:58 PM
  #64
Tennpenn83's Avatar
correct. 13mm i think. don't forget to disconnect the power line and wiring from it to take it out
Old Mar 27, 2011 | 12:18 AM
  #65
from the alternator? yeah, I am replacing that as well so it's coming out anyway. I still can't seem to get the manifold off though.
Old Mar 27, 2011 | 12:27 AM
  #66
Nighthawk243's Avatar
Yeah my intake manifold is already off. I did find a how to with the core changing. But that is it then right? There aren't any special tools or other parts I'd need? If this is so simple why doesn't GM do this lol.
Per the Stage III manual, they cited that it was not done in order to simplify assembly.
In other words, they didn't trust the assembly line workers to not screw it up and also probably didn't want to pay the extra money for the extra plumbing.
Plus anyways, they could make more money by selling the GM performance Dual Pass endplate and Option B parts for their usual "rape yo ass w/o lube" price.
Old Mar 27, 2011 | 08:11 AM
  #67
05Slowline's Avatar
did you take the dipstick off of it lol
Old Mar 27, 2011 | 08:33 PM
  #68
so i did not. I have to remove the dipstick to get it out?
Old Mar 27, 2011 | 08:56 PM
  #69
Tennpenn83's Avatar
the dipstick is bolted to the side of the IM from the factory... i assumed you would have seen that
Old Mar 27, 2011 | 09:02 PM
  #70
nizzle's Avatar
Also there is a bolt in the left side of the IM that took me forever to find. If you are looking at the motor it's on the left and kinda hidden. Did you get that bolt out yet?
Old Mar 27, 2011 | 09:05 PM
  #71
05Slowline's Avatar
only thing i can think of is he didn't take the one dipstick bolt off, or he left the 2 e-torx rods in it thinking that the nuts were all that was holding it on
Old Mar 27, 2011 | 09:16 PM
  #72
BlilBT's Avatar
Like stated above there is one hidden behind the IM that mounts it to the motor, a pain to get to!
Old Mar 27, 2011 | 09:24 PM
  #73
Well I have a 2.2 with the LSJ intake manifold on it. So would my dipstick be bolted to the manifold?
Old Mar 27, 2011 | 09:57 PM
  #74
05Slowline's Avatar
did you screw the dipstick into it
i thought you said the im was already off anyways?
Old Mar 27, 2011 | 10:08 PM
  #75
No the intake manifold is what I can't get off. I have the top bolts off but can't seem to get the bottom one out. I got the alternator bolts out so I'll remove that tomorrow and hopefully I can get that last bastard bolt then. Also just ordered an Option B kit and am going to remove the IC pump tomorrow to see if it works or not.
