Question about dual pass endplates
there is really no need. i hate to be rude but you are seriously making this harder than it needs to be.
if you want to remove the ic pump and bracket, you can, but it's not going to help any in getting to the bolt from the top. this would really only help if you were going up from under the car, which, if given a choice, i go from the top
Ok I finally got it off. Thank you very much for the help. I didn't realize this bolt when in perpendicular to the other bolts. I kept trying to remove the two bolts that hold on that little piece.
Yeah first time I've seen the cores in that manifold. Could be why I'm having some cooling issues. Good thing I'm taking this apart. So in two outputs from the endplate should go to the what???
Yeah bought it used for my supercharger build. I'm gonna rearrange the cores according to the diagram on ccf. Also can someone tell me if this is correct for my plumbing setup. The outer lines of the endplate go to a Y then to the filler neck, then the filler neck flows to the heat exchanger input and somewhere in that line put a T fitting for my option B tank. Then the heat exchanger flows to the pump then pump to the single input of the endplate. That correct?
