Question about dual pass endplates
Old Mar 27, 2011 | 10:28 PM
  #76
05Slowline's Avatar
not that hard you just stick your hand down there and you'll feel it, then leave your hand on it and take the socket down there to it, kinda like the first time you get laid
Old Mar 28, 2011 | 03:50 AM
  #77
Tennpenn83's Avatar
? i don't know about you but i have a bolt and not a socket... lmao
Old Mar 28, 2011 | 04:35 PM
  #78
redcobalt07's Avatar
Ok still unsure how to get this god damn intake manifold off. Still can't figure it out. Does anyone have pics at all?
Old Mar 28, 2011 | 04:37 PM
  #79
nizzle's Avatar
http://www.crateenginedepot.com/store/pdfs/sidekit.pdf
Old Mar 28, 2011 | 07:21 PM
  #80
05Slowline's Avatar
it's not rocket science, take off the visible bolts, take the bottom bolt off, take the two nuts off of the threaded rods, take off the threaded rods, etorx 7 iirc
Old Mar 28, 2011 | 07:48 PM
  #81
Tennpenn83's Avatar
hard to make it any simpler than that bud
Old Mar 28, 2011 | 11:49 PM
  #82
Thank you TennPenn, that is going to help a lot. Should I remove the intercooler pump and bracket as well?
Old Mar 29, 2011 | 04:06 AM
  #83
Tennpenn83's Avatar
there is really no need. i hate to be rude but you are seriously making this harder than it needs to be.
if you want to remove the ic pump and bracket, you can, but it's not going to help any in getting to the bolt from the top. this would really only help if you were going up from under the car, which, if given a choice, i go from the top
Old Mar 29, 2011 | 06:16 PM
  #84
05Slowline's Avatar
rofl
Old Mar 29, 2011 | 06:39 PM
  #85
Ok thanks. I'll take another stab at it now. It's a 15mm bolt right
Old Mar 29, 2011 | 06:41 PM
  #86
05Slowline's Avatar
here comes the airplane, open your mouth like a good boy here it comes brrrrr brrrrr
go out with a socket set and try it till you're done damn
Old Mar 29, 2011 | 06:49 PM
  #87
BlilBT's Avatar
Old Mar 29, 2011 | 07:23 PM
  #88
05Slowline's Avatar
Originally Posted by BlilBT
for real lol it's only been already mentioned in the thread like 3 times now jeeze
Old Mar 29, 2011 | 10:33 PM
  #89
Ok I finally got it off. Thank you very much for the help. I didn't realize this bolt when in perpendicular to the other bolts. I kept trying to remove the two bolts that hold on that little piece.
Old Mar 29, 2011 | 10:45 PM
  #90
So this is how my intake looks when I took it off. It is different than the one pictured on the how to.
Old Mar 29, 2011 | 10:51 PM
  #91
advise's Avatar
might wanna check the o ring on the second core from the top
Old Mar 29, 2011 | 10:53 PM
  #92
nizzle's Avatar
you didnt touch those cores at all? because the way those are arranged wont work for single or dual pass.
Old Mar 29, 2011 | 11:03 PM
  #93
troyss's Avatar
Yeah there should be two of them with holes in them and two without
Old Mar 29, 2011 | 11:08 PM
  #94
05Slowline's Avatar
lol wtf
Old Mar 29, 2011 | 11:10 PM
  #95
Yeah first time I've seen the cores in that manifold. Could be why I'm having some cooling issues. Good thing I'm taking this apart. So in two outputs from the endplate should go to the what???
Old Mar 29, 2011 | 11:46 PM
  #96
nizzle's Avatar
you buy this used? looks like someone had been in there b4 you.
Old Mar 30, 2011 | 12:00 AM
  #97
Yeah bought it used for my supercharger build. I'm gonna rearrange the cores according to the diagram on ccf. Also can someone tell me if this is correct for my plumbing setup. The outer lines of the endplate go to a Y then to the filler neck, then the filler neck flows to the heat exchanger input and somewhere in that line put a T fitting for my option B tank. Then the heat exchanger flows to the pump then pump to the single input of the endplate. That correct?
Old Mar 30, 2011 | 12:38 AM
  #98
Also what should these cores smell like? They smell like oil.
Old Mar 30, 2011 | 01:03 AM
  #99
nizzle's Avatar
just click on this
Old Mar 30, 2011 | 01:09 AM
  #100
nothing showed up in that link
