Racing solutions 2.2 header installed! (lots of pics)
Old May 8, 2009 | 10:22 AM
OBZ's Avatar
OBZ
It shifted it a little further up, but i feel like i got more power throughout the entire RPM range. I love this header!
Old May 8, 2009 | 01:32 PM
Sw4y1313's Avatar
Looks clean Tyler! When are you gonna bring that thing up so I can see it? Both our cars have changed drastically since we last met up. Race? jk!
Old May 8, 2009 | 01:33 PM
1badBlueberrySC's Avatar
That is actually a Cobalt Adiction shorty!
Old May 8, 2009 | 01:37 PM
jhs87's Avatar
Originally Posted by Black SS/SC 06
Reading > You
lmao x2
Old May 8, 2009 | 02:08 PM
MadBrad's Avatar
If so, why so cheap compared to CA website?
Old May 8, 2009 | 02:38 PM
Check on ebay... you can get them their all day long for 175-200.00 I had one from them that I bought on Ebay for my LSJ that was 200.00!
Old May 8, 2009 | 04:27 PM
philupondes's Avatar
looks good but you should have wiped the header down with some achoal before you started it up to make it nice and clean, but once you start it and get it hot with that oil on it you are screwed
Old May 8, 2009 | 04:53 PM
OBZ's Avatar
OBZ
Thanks bro! I really do need to come up there soon! My nephew just turned 5! I need to see the little guy!
We'll race! bracket status!
Actually NO its not.. they are very similar.. but have a different tubing design..
Notice the difference..
Racing solution header..
CA header..
Old May 14, 2009 | 11:37 PM
Mike85220's Avatar
I see that you said it shifted the powerband up a little.
Does that mean your low end took a dive or is a little less than it was?
I am almost certain I want one of these, but I value my low end.
Old May 14, 2009 | 11:44 PM
ebristol's Avatar
Originally Posted by Sizzle06
Looks exactly like the CA V2 header
Its the Cobalt Addiction V1 header.
It is.
They were both made by Cobalt addition. After CA came up with the new design (V2) they sold off their first design to Racing Solutions.
Old May 15, 2009 | 12:21 AM
  #36
StrongIslandBalter's Avatar
so if you go with racing solutions what downpipe can you get for an automatic to fit perfect
Old May 15, 2009 | 12:44 AM
  #37
ebristol's Avatar
Stock?
Or any dp that bolts into the stock location. ZZP, CTI, etc.
Old May 15, 2009 | 07:27 AM
  #38
007CobaltLS's Avatar
We can't use the stock LSJ DP since it's shorter (it'll either rub or be too tight). We have to use an aftermarket...ZZP is what I would recommend, but any will work.
Old Dec 9, 2009 | 06:04 PM
  #39
Toasted08cobalt2.2's Avatar
im putting this same header on and i ran in to a problem the pipe is hitting on of my coolant lines and causing it to leak. any reason why it would do that ?
Old Dec 9, 2009 | 06:09 PM
  #40
Maven's Avatar
Because this header wasnt designed for 2nd gen L61s.
Old Dec 9, 2009 | 06:13 PM
  #41
is there any way around that problem or am i screwed ? it came off a newer ss
Old Dec 9, 2009 | 10:42 PM
  #42
Mike85220's Avatar
Are you saying it works on 05-07's without hitting a coolant line, but not the 08+ Cobalts?
Old Dec 9, 2009 | 10:55 PM
  #43
glen229's Avatar
theres a tab on the coolant tube, flatten it and rotate the whole pipe out of the way, use a flat head screwdriver and the then give it a good pull and it will rotaed out of the way
same thing happend to me a long time ago
Old Dec 10, 2009 | 10:32 PM
  #44
Mike85220's Avatar
Does this rerouting of the coolant line only exist in the 08+ Cobalt 2.2s?
Turbo Johnny
Feb 21, 2019 09:41 AM
Barkleyj605
Oct 24, 2015 12:07 AM
Cptnslo
Sep 24, 2015 09:32 AM
BettyBlue2.2
Sep 10, 2015 08:49 PM
