Rough idle with a/c
Old Sep 23, 2014 | 02:27 PM
NateD35's Avatar
Rough idle with a/c
So I've noticed lately that my car has been jumping rpms when idling. I've narrowed it down to just when I'm idling and I have the a/c on. Will cleaning the throttle body solve this or do I need to get my IAC checked?
Old Sep 23, 2014 | 04:40 PM
Jesse's Avatar
Mods? These cars don't have IAC valves. The computer just opens the throttle a little bit instead.
Old Sep 24, 2014 | 08:40 AM
NateD35's Avatar
Just a cat back exhaust but that shouldn't effect anything
Old Sep 24, 2014 | 08:50 AM
umrdyldo's Avatar
First is to clean the throttle body. If it's never been done it will be very dirty.
This is not uncommon with these cars.
Old Sep 24, 2014 | 02:11 PM
NateD35's Avatar
What's the proper way to clean the throttle body? I've heard different things as far as what to be careful about.
Old Sep 24, 2014 | 06:04 PM
In for results
Old Sep 24, 2014 | 07:16 PM
umrdyldo's Avatar
Make sure the car hasn't been started in like 15 minutes. No key on, nothing.
Unhook negative side of battery and put safely aside. Unhook intake. Unhook also sensors and anything from throttle body. All bolts. Spray throttle body clean onto a towel, not the TB itself. Stay away from spraying any sensors.
Do not rotate the butterfly. Wipe off all soot and then Reverse.
There is a post on here if you have throttle body issues after install. Should be no problem.
Old Oct 27, 2014 | 02:47 AM
Jesse's Avatar
I'm bringing this back because as I dive down into the E37 computer, I find more and more things I need to fix. Like this ******* mess. It is an adaptive idle table that adds or subtracts air with RPM error. And the 2.2 has ridiculous numbers stock. Like 2lbs per minute. Looks retarded:
Old Oct 29, 2014 | 12:52 PM
Jesse's Avatar
So for kicks, today I 1: replaced the values in that table with the stock values from a 2.4L. I got retarded low idle (450rpm) and it would hunt for the idle badly. This was before the AC was even on. So scratch that. 2: Next I interpolated the 0s in the stock table and then halved the entire thing. This put my adaptive idle airflow at 1lb an hour, which is double my realistic idle airflow. This time my problem was a high idle. About 1000-1100rpm and it had hanging idle. Finally, I interpolated away all the zeros and left them alone.
MAGIC!
The car idles fine. It also didn't fluctuate RPMs when I turned on the AC. I don't understand why it has such high numbers, when a 7.0L V8 doesn't even need those kind of numbers, but that is what worked for me. I'd also like to add that I made the AC torque reduction table more uniform at lower RPM.
I am going to go for a drive and report back, then probably write a post about it on HP Tuners forum and add a link here in this post.
Old Nov 5, 2014 | 08:36 PM
Jesse's Avatar
Does your L61 (RPM and AFR) idle weird when you turn on your A/C? Step inside.
Yeah this works. If you guys have a tuner, please feel free to link them to that thread.
bigdeertz
Nov 17, 2016 09:41 AM
Oct 13, 2015 09:32 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Trav3480
Sep 28, 2015 02:46 PM
