Ruff Idle?
Old Apr 10, 2009 | 08:42 PM
ctcsoccer7's Avatar
Ruff Idle?
Any Reason The Idle Would Be So Ruff On A Cobalt Lt 2006?
Old Apr 10, 2009 | 09:01 PM
HunterKiller89's Avatar
clean the throttle body
Old Apr 10, 2009 | 09:03 PM
XM15's Avatar
That seems to be the solution on the 2.0's. Couldn't hurt; its pretty simple to get at.
Old Apr 10, 2009 | 09:19 PM
ctcsoccer7's Avatar
ok honestly your talking to someone who isnt the sharpest tool in the box, any how tos on this? or pics?
Old Apr 10, 2009 | 09:23 PM
Jn2's Avatar
Jn2
u could always run soem seafoam thru the car, and if you've never cleaned the TB off, im sure its filthy, mine was filthy after the frist year, nw i clean it every 4-6months
Old Apr 10, 2009 | 09:24 PM
Wolf117's Avatar
like a dog ruffs? jk lol but X2 about the throttle body
Old Apr 10, 2009 | 09:41 PM
remove the big black thing under your hood...thats part of the stock air box. There should be a clamp holding it in place.
Once it's off, you'll be looking at your throttle body. Remove the 4 bolts holding it in place, unclip the wiring clip, and spray the inside with engine degreaser or throttle body cleaner or brake cleaner, etc. Use a Q-Tip to get at the hard to reach corners, and just clean it all out. Then reinstall
Maybe a 15 minute job
Old Apr 10, 2009 | 11:02 PM
ctcsoccer7's Avatar
k thanks!
Old Apr 10, 2009 | 11:16 PM
i forgot to mention this, but be sure to remove the throttle body before spraying it with cleaner!
Im sure you figured that much on your own, since i explained how to remove the throttle body, but i noticed i left that little detail out of my directions. You dont really want engine degreaser getting inside your engine after all...lol
Old Apr 10, 2009 | 11:18 PM
ctcsoccer7's Avatar
yeah gotcha..if you know of any pics or have some let me know!
Old Apr 10, 2009 | 11:30 PM
remove this black piece:
Then the 4 bolts that hold the TB in place. It will look like this when then TB is removed:
I have some other stuff removed, so it wont look EXACTLY like that, but you should be able to get it from there
Old Apr 12, 2009 | 01:49 PM
ctcsoccer7's Avatar
then the 4 bolts that hold the tb in place. It will look like this when then tb is removed:
i have some other stuff removed, so it wont look exactly like that, but you should be able to get it from there
sweet got it.....!
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
