Slowbalt2000's SmallturboL61coupe Build
But in this case I am asking about you specifically because through this whole adventure I have learned something about boost, the mathematical equations in determining boost, and how to read boost maps. This is all good and all but then there comes real-world experience.
You're using the same engine as I am so your equations should be about the same as mine. I plotted my engine on many, many compressor maps at multiple power levels. On the K04 my engine literally wasn't even on the map. It was so far outside the choke line that I wouldn't even have considered using it. If you read the numerous "LNF on LE5" threads on the internet there are almost none that actually got completed. Most of them end in some people who claim to know about turbos telling the people that want to build turbos that the K04 will never work on the LE5, which I agree, on paper it is a terrible candidate. But then there is you.
I will also say that, on paper, the K04 doesn't really even appear to be a great candidate for the stock LNF. It is barely within the choke line. I guess that just confirms what people say about it though. It spools fast as hell and runs out after 5300rpm.
Haha, assuming everything goes as planned, I WILL be using a 2871, not WANT TO.
Edit : nm, I missed the r in your second post.
With the k04r being a big wheel its weakness is the exhauat turbine being small but you guys havingbthe bigger engine i think would love it. I personally would only spend my money on the k04r or the 7163. Having had both I'd say they are both tons of fun and the R will be all you guys need for a stock bottom end le5
https://www.cobaltss.net/forums/2-0l...o-swap-310943/
