squires turbo systems remote mount, update
Old May 20, 2008 | 02:56 PM
  #226
06black's Avatar
because hes trying to pull oil out of the block.......
try to keep up here.
Old May 20, 2008 | 03:05 PM
  #227
xCobalt05x's Avatar
if its the same soze as the one for the n2o why not use that one?
if it was that easy, it would have been done already but considering the hole that is on the block is about ohhhh id say 10 times bigger then the an-4 fitting at the end of the hose, not to mention that its a female fitting on the block and the hose end is also a female fitting, need one male and one female enorder for it to work. think of the hole on the block as the size of a nickle and the hole on the end of the hose is the size of a dime, need something to step down the big hole to the size of the little hole.
Old May 20, 2008 | 04:39 PM
  #228
IonNinja's Avatar
I think hes just asking why you can't use your nitrous line for the oil return which if that is a -4AN fitting it should technically work but then thats not your issue in the first place.
Old May 20, 2008 | 05:26 PM
  #229
xCobalt05x's Avatar
i knew what he was getting at so i just had to clearify what my issue was. good call though
I found this picture of an engine mounted turbo.... Look how hot this thing gets
Last edited by xCobalt05x; May 20, 2008 at 05:26 PM. Reason: Automerged Doublepost
Old May 20, 2008 | 05:37 PM
  #230
IonFeright's Avatar
I hope that wasnt your reason for buying a remote mount...that, or "the sound it makes"...
And how do you plan on hitting up the track Friday if you dont have a tune?
Old May 20, 2008 | 05:45 PM
  #231
06blackg85ss's Avatar
wonder if my **** glows like that... I know my DP used to when I was s/c'd lol.
Old May 20, 2008 | 05:49 PM
  #232
xCobalt05x's Avatar
its already tuned for 10psi of boost my friend, i just orderd the fitting i need from hahn via phone call and they are over nighting it. will be here tomorrow after noon. vince and i are going to be spending an hour on the dyno getting afr's and tweaking and peaking the base 10psi boost tune that we already loaded up on the car
Old May 20, 2008 | 05:52 PM
  #233
Area47's Avatar
Rent me! per hour
if you push it to 2k degree's yes.
Old May 20, 2008 | 05:54 PM
  #234
xCobalt05x's Avatar
here is a quote from sts that i just love to death.... pulled it off their web site
We encourage you to continue your investigation into the many benefits of STS remote-mounted turbocharging, and remind you not to always trust the uninformed traditionalist masses, i.e. uniformed traditionalists used to also believe the earth was flat.
STS Turbo is The Smart Choice in forced induction!
Old May 20, 2008 | 05:56 PM
  #235
elecblue06's Avatar
.. yea there's also another saying..
don't believe everything you read... i wanna see your numbers vs a comparable 2.2 build.. no **** they're gonna say something like that to get you to buy their ****...
  #236
IonFeright's Avatar
that sounds like a pro-tabacco ad.
Old May 20, 2008 | 05:57 PM
  #237
xCobalt05x's Avatar
double post here
i found this on their site too
Benefits of STS Remote-Mounted Turbochargers
Ease of installation. STS turbo systems can be installed in about 8 hours with standard tools and average mechanical ability.
Performance Sound. The turbo acts as a muffler and sounds like an aftermarket performance muffler. Turbo spool and rushing air from the blow-off valve make a unique sound that will turn heads!
No need for major modifications to your vehicle. STS systems are designed to "bolt-on" to factory mounts.
Increased gas mileage. Unlike a belt driven supercharger, the turbo utilizes "wasted" energy leaving your tailpipe. Most of our customers get 1-3 mpg increase in gas mileage compared to their original stock mpg numbers.
Lower underhood temperatures. No need to worry about melting wires, hoses, or other components.
Converts back to stock in about an hour.
More room under the hood. Future repair work or modifications will not require the expense of removing the turbo system to allow access to engine components.
Cooler oil to the turbo. Cool oil is better for both the turbo and engine.
Approximately 500F lower turbo temperatures. Eliminates the need for a turbo-timer, which allows the engine to run after the car is shut off in order to cool down the turbo and prevent oil and bearing damage.
Denser exhaust gasses drive the turbo turbine wheel more efficiently.
Built-in intercooling. Intake piping provides ~50% intercooler efficiency. There is no need for the expense, pressure drop, and installation problems associated with a front mounted intercooler.
Turbo is exposed to ambient air rather than underhood air. Allows for better cooling of turbo components.
No need for expensive headers, mufflers, or exhaust systems.
Turbo is closer to the tail pipe outlet. Provides a better pressure differential across the turbine wheel which promotes better flow across turbine.
Better weight transfer. Increases traction because the bulk of system is mounted in rear of vehicle rather than up front.
Less noise in the passenger compartment.
Old May 20, 2008 | 06:04 PM
  #238
elecblue06's Avatar
wow.. seriously.. .. sorry man it's your project but you're ******* dense.. they;re web site should say all that.. THEY"RE TRYING TO SELL IT TO YOU!!!
does eatons stuff say.. woefully inefficient massive heat production and limited up-gradability no.. **** man..
if we're going based on what their website says then the procharger is about 200000000000x better then anything out there.. but in reality it totally isn't
Old May 20, 2008 | 06:07 PM
  #239
Area47's Avatar
Rent me! per hour
pressure drop eh?
3 ft long intercooler vs 10 ft of piping.
Old May 20, 2008 | 06:08 PM
  #240
xCobalt05x's Avatar
hmm its funny that all the shops out here that have installed the sts on other cars believed the same thing as the rest of you and then after they put the car on the dyno they were turned believers.
Old May 20, 2008 | 06:10 PM
  #241
Area47's Avatar
Rent me! per hour
there is an sts integra here in kc. got raped by a "traditional" style turbo teg.
im not saying they don't work, they serve a purpose.
if sts kits are so damn good. why is it some of the fastest cars in the country have turbo's within 3 ft of the engine?
Old May 20, 2008 | 06:17 PM
  #242
don't give me any ideas lol
  #243
elecblue06's Avatar
at 3k+ for install no **** they were "turned into believers" they make a shitload of money off of it
Old May 20, 2008 | 06:21 PM
  #244
thats a great line right there, def sig worthy
Old May 20, 2008 | 06:25 PM
  #245
Area47's Avatar
Rent me! per hour
thats the only way you're going to see a turbo glow orange, yellow, white.
if you can see through the header/exhaust housing. rest asured, you just melted all 4.
before i get flamed by the op. i have seen sts cars run 9's with an sts kit and a built nasty motor.
can it make power? yes, can it do it efficiently? not exactly.
heat affects spool time.
Old May 20, 2008 | 06:27 PM
  #246
jimbos'ss's Avatar
that would be a bad day
Old May 20, 2008 | 06:31 PM
  #247
elecblue06's Avatar
exactly what the Op isn't understanding..
there are all motor cars that run 9's ... is it the best way to do things and most cost effective... **** no..
Old May 20, 2008 | 06:45 PM
  #248
victory_red_SS's Avatar
LSX RWD S/C conversion
Does it really matter if the STS is "cost effective" if he has already bought and paid for it??? The results at this point are all that matter.
And on the cost effective part once more, does anyone actually think my car is "cost effective??? No f'ing way but I am not getting this crap.
Old May 20, 2008 | 06:47 PM
  #249
Area47's Avatar
Rent me! per hour
your car is cost effective compared to a veyron
Old May 20, 2008 | 06:49 PM
  #250
cost effective is not what I believe nor will argue with the op on. I'm happy he at least decided to go turbo.
It's probably going to be a bit laggy and if he dropped compression low end power will definitely suffer. But once it does spool car should be pretty fast.
As for pressure drop, 10' of 2.5" or 3" piping in some cases would have less pressure drop dependin on the Cubic ft volume of the intercooler.
well pretty much anything is lol
Last edited by 06blackg85ss; May 20, 2008 at 06:49 PM. Reason: Automerged Doublepost
