Ss/sc Injectors In 2.2
Old Mar 26, 2007 | 12:57 PM
  #51
06_ion2's Avatar
Originally Posted by Psykostevo
LOL, that's a crock of ****! The computer CAN'T do that without tuning!
And I tried to put the 34#'s in the 2.2L Ecotec, and they DON'T FIT. I would like and explanation of how they got them in (it does look possible with a bit of modification), and how WaltDisney came back to life and Mickey Moused his ECU, because that "learning" business is a total crock! If you think the 2.2L ECU is smart, take a look at its tuning file. It's about as complicated as making Toast, dry toast.
im sorry but someone in a ion just proved you wrong the computer corrects the afr to the other injectors.. if you dont believe me than look at this ***************************/viewtopic.p...r=asc&start=40 (will delete if mods dont like it)
Old Mar 26, 2007 | 03:24 PM
  #52
IonNinja's Avatar
correct it did correct it during idle but not at partial throttle or WOT
so it seems to work ok at idle but not anytime else...
also he has an 04 Ion which is more closely related to the 2.2 eco found in Cavaliers which is probably where your 2.2 harness is coming from.
Old Mar 26, 2007 | 05:53 PM
  #53
Psykostevo's Avatar
You're talking about Fuel trim learning, not Flow rate adjutments. Your car can correct for about a 18% difference, but it is not good for it, because of of your other calibrations are based upon teh flow data.
His car did not learn......it was just trying to come up for air.
Other than that he did a great write up, tons of pics. I can see that the injector swap will most likely fit in the 2.2L Cobalt and Ion, because the fuel rail is way different than the Cavy, sunfire.
Old Sep 22, 2007 | 09:07 PM
  #54
RedBaseBolt's Avatar
Dead thread revived!!!
I so as I understand according to this thread, I can install SS injectors in my car but it will not add power and might run the risk of messing up my idle?
Old Sep 22, 2007 | 09:34 PM
  #55
randizzle's Avatar
this is all you need to know... no reason to do the swap.
Old Sep 22, 2007 | 09:49 PM
  #56
06cobaltls's Avatar
You should really invest some time in reading! IF YOU TUNE YOU WILL RUN THE SAME! Bigger injectors are not going to make your car run like ****!
common sense would tell you with tuning they would work, but unless you go piggy back on the 2.2 then you dont have tuning. And yes to much fuel will make your a/f ratio off depending on the oversize of the injector to stock and will affect performance
Old Sep 23, 2007 | 04:06 AM
  #57
Novajoe's Avatar
wow. reading this thread just reminded me of how many people have a complete lack of common sense
Old Sep 23, 2007 | 03:14 PM
  #58
Sw4y1313's Avatar
you and me both nova =P
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
