Is surface rust normal on pistons?
So I was changing my sparkplugs the other day and I ran a small light down into the cylinder and noticed that the pistons all seem to have what looks like small deposites of surface rust on them.
There is practically no carbon build up at all. You can still see the surface of the piston clearly.
Any thoughts?
Is this normal?
Any thoughts?
Is this normal?
I guess I have some carbon on my pistons...time for a clean up
Not bad considering the car has 167, 000 kms on it....
yeah...do the sea foam.....
aluminum doesn't rust...but it does build up a coating that is one of the strongest known to man....Aluminum Oxide....(in case you are wondering it is in most sand paper and grinder wheels)....so pretty much what you are looking at is a carbon build up with maybe a hint of oil/fuel giving that reddish color...
You can suck it up through the brake booster hose on the 2.2/2.4's
i'm gonna try this next week most likely.
Although through some research I've heard a good steam clean can help almost as much
lol seafoam is steamcleaning lol...and use the oil seperator hose that goes to ur intake...goes from intake to the top of the head...thats what i used cause i heard the brake booster is a pain to get to in the 2.2
