Is surface rust normal on pistons?
Old Apr 3, 2008 | 09:07 AM
RedBaseBolt's Avatar
So I was changing my sparkplugs the other day and I ran a small light down into the cylinder and noticed that the pistons all seem to have what looks like small deposites of surface rust on them.
There is practically no carbon build up at all. You can still see the surface of the piston clearly.
Any thoughts?
Is this normal?
Old Apr 3, 2008 | 10:56 AM
TurboTechRacing's Avatar
There is no way it is rust, it is carbon you see down the spark plug hole, which is 100% normal.
Old Apr 3, 2008 | 11:05 AM
IonNinja's Avatar
there were no surface rust on mine when we pulled the head
in fact, mine looked pretty clean
Old Apr 3, 2008 | 11:06 AM
SilvrLT's Avatar
X2
Old Apr 3, 2008 | 11:08 AM
redlineblueline's Avatar
sea foam time
Old Apr 3, 2008 | 11:10 AM
HackAbuse's Avatar
Originally Posted by redlineblueline
sea foam time
That **** rocks
Old Apr 3, 2008 | 11:11 AM
cool, thanks for the help. I wasn't sure what it was but there was only vary sparse pieces of the pistons covered. I figured I would ask at least.
Old Apr 3, 2008 | 11:12 AM
Originally Posted by HackAbuse
That **** rocks
i'm gonna snag a can for this weekend when i does my oil change i'll throw some in the oil drive around suck some in the engine and change the oil
Old Apr 3, 2008 | 11:14 AM
how will sea foam remove deposites on pistons?
Old Apr 3, 2008 | 11:17 AM
Halfcent's Avatar
I'm old school
It can't be rust, because your pistons are aluminum.
It more then likely is in fact carbon.
Aw damn, posted too slow.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
Old Apr 3, 2008 | 11:24 AM
kick ass. gotta get me some.
I guess I have some carbon on my pistons...time for a clean up
Not bad considering the car has 167, 000 kms on it....
Old Apr 3, 2008 | 07:19 PM
FacelessKhaos's Avatar
yeah...do the sea foam.....
aluminum doesn't rust...but it does build up a coating that is one of the strongest known to man....Aluminum Oxide....(in case you are wondering it is in most sand paper and grinder wheels)....so pretty much what you are looking at is a carbon build up with maybe a hint of oil/fuel giving that reddish color...
Old Apr 3, 2008 | 07:21 PM
Frankruffolo257's Avatar
you run it thru the intake, putting it in the oil wont clean the pistons.
Old Apr 3, 2008 | 07:24 PM
YellowLT's Avatar
half in the gas half in the oil
Old Apr 3, 2008 | 07:30 PM
steddy2112's Avatar
Could you use the breather hose from the crank case to suck it up?
Old Apr 4, 2008 | 02:22 AM
Sloco Productions's Avatar
thats what i did...i noticed a little more pep to her after
Old Apr 4, 2008 | 02:55 AM
dont use the breather hose on the lsj use the line coming from the intake manifold to bypass unit...on the 2.2/2.4 i dont know what you would use
Old Apr 4, 2008 | 11:46 AM
You can suck it up through the brake booster hose on the 2.2/2.4's
i'm gonna try this next week most likely.
Although through some research I've heard a good steam clean can help almost as much
Old Apr 5, 2008 | 09:22 PM
lol seafoam is steamcleaning lol...and use the oil seperator hose that goes to ur intake...goes from intake to the top of the head...thats what i used cause i heard the brake booster is a pain to get to in the 2.2
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Oct 21, 2015 11:57 PM
Oct 20, 2015 09:56 PM
