Throttle Response
Old Jun 17, 2008 | 12:47 AM
Ramphex's Avatar
Throttle Response
Is it me or is the throttle response in Neutral is kind of off by a little? If you rev the engine in N, it doesn't rev up right away, it has a little pause and then it revs.. Is it supposed to be like that because in my old car once you hit the gas pedal the tach goes up and the engine is roaring... here it delays and then revs.
Old Jun 17, 2008 | 12:49 AM
EceSSiveMod's Avatar
yes they are all like that until u get a better tune
USAF1123's Avatar
try the intake mod from the "how too" section. it takes like 45 minutes tops. All you need is a 10mm wrench, 10mm socket, and 7mm socket.
Old Jun 17, 2008 | 12:55 AM
Blue_Balt's Avatar
Why are you revving the engine in neutral.?
Old Jun 17, 2008 | 12:57 AM
Ramphex's Avatar
Just wanted to see how it sounds stock... I tend to do it on all cars, just a little rev none of the redline craziness.. I'm thinking about CAI tho, and from suggesting the intake mod I take it that it's not the TPS that's affecting it but the restriction in the stock airbox?
Old Jun 17, 2008 | 01:07 AM
BigTizzle903's Avatar
not 100% here but wouldnt the electronic drive by wire have something to do with it?
Old Jun 17, 2008 | 03:50 AM
HunterKiller89's Avatar
this is what im thinking. if your cruising at a high RPM, and mash the gas, throttle response is instantaneous. but in N, theres a little delay.
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Oct 13, 2015 09:32 PM
importkiller
Sep 30, 2015 07:18 PM
