Timing Chain Tensioner
Old Feb 18, 2012 | 02:12 PM
scagnetti76's Avatar
its the one on the rear of the motor, im just having a hard time getting some type of leverage to get it in
Wish I had that problem.
But you have any luck. It should just thread in, no leverage should be needed.
Old Feb 18, 2012 | 02:18 PM
i got it on my 4th attempt haha i was extremely happy it thread....i didnt even know it thread is just kept ratcheting it and i was like wait.... pulled the socket and it threads
car runs good, it wasnt my ticking problem tho(exhaust leak probably). Glad the new design is installed and off the list
Old Feb 18, 2012 | 02:46 PM
Haha, I did mine because of an exhaust leak too. Figured it was easier, and I was being lazy And figured if it wasnt the tick, it wasnt going to hurt anything.
Gelladuga69's Avatar
I see that CED has a timing chain tensioner bolt listed. Is that required?
Also, I assume all you guys bought the ACDelco part, iinstead of off-brand Cloyes(?), right?
Old Feb 18, 2012 | 03:10 PM
No need for the bolt, just the updated tensioner. And I got the Delco one.
Old Feb 18, 2012 | 03:20 PM
yea pretty much when its done, it done
i checked the usually spots it leaks and header was good and so was the dp 2 the header
it sounds like it could just be a normal sound the motor makes combined with the cat about to go or idk who cares the timing chain tensioner is installed WOOOO haha
Old Feb 18, 2012 | 03:26 PM
chris88z24's Avatar
Mine makes a whooshing air sound under boost but I think its just the sound of the air going through that thin flex section (OEM exhaust). IDK or care anymore lol
Old Feb 18, 2012 | 03:42 PM
Thank you, sir.
Can anybody tell me the required tools needed take out old/put in new?
Old Feb 18, 2012 | 03:53 PM
Iirc its a 32mm socket, and torque it to spec. Dont remember what that is off the top of my head though.
Edit: Just found it, 55 ft lbs.
Old Feb 18, 2012 | 05:47 PM
chris88z24's Avatar
FYI - when rethreading the new tensioner, make sure you press on it with a CONSIDERABLE amount of force while simultaneously turning the bolthead. Otherwise the threads won't catch.
Old Feb 18, 2012 | 08:17 PM
  #36
drumrush's Avatar
I didn't need much force at all to get it threaded in, and it torqued down without a problem
Old Feb 19, 2012 | 10:33 AM
  #37
cavfiredesire's Avatar
I pulled my new one apart since I read I was supposed to set something. But didn't see anything. So I compressed it and re-installed the retaining clip.
Should it be good to go or is there something I have to do because I took the plunger out???
The way it sits the tensioner tip is spring loaded and takes a fair effort to press in still.
Im beyond paranoid to do this since this is my daily driver.
Old Feb 19, 2012 | 11:11 AM
  #38
conerboner's Avatar
you're not supposed to take it apart, you just take the old one out and put the new one in and start the car and it sets itself. You guys are making this way too big of a deal
Old Feb 19, 2012 | 11:23 AM
  #39
drumrush's Avatar
I still hear a rattle under slight acceleration and when accelerating from a stop. I'm guessing its something different?
Old Feb 19, 2012 | 11:25 AM
  #40
conerboner's Avatar
meh it's a cobalt they rattle everywhere lol
Old Feb 19, 2012 | 12:04 PM
  #41
drumrush's Avatar
It's coming from the engine bay, but goes away when it hits 2500 rpm.
It my engine blows im buying a subaru so im not too worried about it haha
Old Feb 19, 2012 | 12:11 PM
  #42
Powell Race Parts's Avatar
^^^^ x 277880089078603
Old Feb 19, 2012 | 09:52 PM
  #43
Its no big deal when youve done it lol.
Im more concerned about **** popping apart into my motor, timing skipping and the vast amount of different opinions about how to do this.
Some say just screw it in.....some say lock it then release it once its screwed in. I cant afford a mistake with my daily.
Old Feb 19, 2012 | 09:57 PM
  #44
conerboner's Avatar
if you have the new lnf timing chain tensioner you just screw it in and start the car. the old style one you do have to set it and tap it
Old Feb 19, 2012 | 10:04 PM
  #45
the number of opinions on a large web site are interesting. in this case, listen to cornerboner.
Old Feb 20, 2012 | 12:00 AM
  #46
USMCFieldMP's Avatar
Rattlesnake Race Shop
In 5 years, this thread will be 10 pages long... and people will still be asking if they can just screw it in and start the car... or do they need to set it.
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
