torque dampener....does it really help? info?
Old Sep 7, 2007 | 05:26 PM
DallasCobalt's Avatar
I installed my damper about an hour ago. On the drive back to work, it seems like it made a world of difference. +1 for Ingalls!
Old Sep 7, 2007 | 05:39 PM
06redlineb's Avatar
why dont people buy the traction bars?they are the same price.i have the t/d and it did not help at all.the traction bars made a world difference.i dont know if its the same for the ss but it helped my redline.
Old Sep 7, 2007 | 09:28 PM
KillerBee's Avatar
well as far as traction bars yeah they are same price and all but with 3 simple to install poly mounts wheel hop is eliminated completely well almost completely i have not had any wheel hop with mine since i have had them
Old Sep 7, 2007 | 09:29 PM
D4u2s0t's Avatar
did you have it tightened? stock from the box it didn't do anything. i tightened it 2 milimeters and made a big difference. if i really get on it there's still some wheel hop, but the way i drive i don't get any now. the tires will actually just spin, then hook up. i'm sure if i tightened it another mili or 2 it would be even better.
Old Sep 7, 2007 | 09:54 PM
XM15's Avatar
Originally Posted by rockstarbass1
Hey guys I'm about to buy this torque dampener for 110 bucks but I'm hearing mixed thing about them yes I know it will fit on my car........ that's not what I'm asking....... will it really help stop the wheel hop? That's my big problem at the track... I lowered my car and I hoped that might of helped a little. But I figured for 110 why not.. Or should I take the money and spend it else where. Get back asap as I'm soposeto be buying it today thanks chris
I wasn't aware that the TD fit on the 2.2; I thought the intake would get in the way.
Old Sep 7, 2007 | 10:02 PM
D4u2s0t's Avatar
if you have aftermarket i think it's ok. the stock airbox would DEF> be in the way though. but don't quote me on that. as far as on the 2.2, i doubt you would even need the td. i never once had wheelhop even after intake and full exhaust. was able to spin the tires, but never had wheelhop.
Old Sep 7, 2007 | 10:44 PM
06redlineb's Avatar
thats how i got mine.just took it for test runs.come back and make them a little tighter.after about there times it was perfect.i can dump the clutch at any rpm and no wheel hop.
Old Sep 7, 2007 | 10:47 PM
D4u2s0t's Avatar
yea, it comes pretty loose. some advice, make sure you check the bolts every now and then. mine wiggled loose!
Old Sep 8, 2007 | 10:17 PM
Correction from previsous.....as soon as I turned on my a/c, the vibrations were crazy. Just a fair warning. I have mine set around 13 mm.
Old Sep 9, 2007 | 03:01 PM
rockstarbass1's Avatar
can some one explain how to adjust this thing to the proper legnth? idk if i have it too stiff or what cuz i dont have the directions,......and the how to on here confused the **** outta me
Old Sep 9, 2007 | 04:48 PM
  #36
gtxsport11's Avatar
so the ingalls td will fit on a 2.2?
Old Sep 9, 2007 | 10:05 PM
  #37
Yes, I have it on my 2.2
Old Sep 10, 2007 | 08:50 PM
  #38
nooooo AND YES......... not an 05 and not all 06 but the 06 and i believe the 07 with the same engine mount as the ljs then it will........... but ONLY with the injen CAI not SRI i guess i got lucky with the lsj motor mount and didnt even know about it when i nput my intake in..... then a year later i find out the TD will work!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
Builttss
Oct 4, 2015 10:21 AM
dieGone
Oct 1, 2015 06:27 PM
