Tvs1320 l61?
Old Mar 17, 2016 | 12:24 PM
  #51
jdbaugh1's Avatar
I am running BKR7E gapped to .032". What should I run instead Slowbalt2000?
I have tried both Lucas and NOS octane booster that is supposed to raise the octane 30 points or 3 octane. Is the Torco stuff more effective?
Old Mar 17, 2016 | 12:43 PM
  #52
I think i run lfr7a. Ltr7ix if you want iridium
Old Mar 17, 2016 | 12:51 PM
  #53
06_ion2's Avatar
Dont run those plugs. They are way too short for an l61
Ran them just fine for over 50k miles already. Zero issues. Several people use them
Old Mar 17, 2016 | 01:06 PM
  #54
Compare them to your stock plugs. They are 1/4" too short. Dont be silly, use the right plugs.
Old Mar 17, 2016 | 03:04 PM
  #55
jdbaugh1's Avatar
Are there any disadvantages with iridium?
Old Mar 17, 2016 | 04:36 PM
  #56
Youre not supposed to gap them but i have. Theyre just more expensive. I use the lfr7a pregapped at .035, works perfect for my turbo le5.
Old Mar 17, 2016 | 04:41 PM
  #57
07blackg5's Avatar
Slobodan Milošević
you can gap them, the tip is just very brittle. You need to exercise caution when gapping them so you don't crack the tip
Old Mar 17, 2016 | 04:56 PM
  #58
Ukchilll's Avatar
I used these and got a terrible idle and misfire st high rpm (7500 )
These work great
BKR8EIX IX iridium NGK 2668
BKR7EIX IX iridium NGK2667
BKR9EIX IX iridium NGK2669
Old Mar 17, 2016 | 05:15 PM
  #59
07blackg5's Avatar
Slobodan Milošević
Those BKR are gasket seat plugs. The l61 and le5 use tapered seat plugs.
The proper tapered seat plugs are
LTR7IX-11 (2-step colder)
LTR6IX-11 (1-step colder)
LTR5IX-11 (Stock)
Old Mar 17, 2016 | 05:43 PM
  #60
jdbaugh1's Avatar
Well I am glad this came up. I was having misfire issues in the higher rpms as well. Hopefully due to the BKR7Es being too short for proper ignition.
Old Mar 17, 2016 | 06:21 PM
  #61
LTR5IX-11 (Stock)
Gasket seat lfr7a work for me
Old Mar 17, 2016 | 09:32 PM
  #62
07blackg5's Avatar
Slobodan Milošević
They will work, but it's not right lol
Old Mar 18, 2016 | 10:17 AM
  #63
Also i wouldnt get the -11. Pretty sure those are pregapped at .043. If you just got ltr7ix they would be gapped at .035.
Old Mar 18, 2016 | 10:33 AM
  #64
Staged07SS's Avatar
Administrator
Administrator
This.
Old Mar 18, 2016 | 10:37 AM
  #65
07blackg5's Avatar
Slobodan Milošević
I have the -11 gapped at .028. Built not bought, yo!
Old Mar 18, 2016 | 02:12 PM
  #66
06_ion2's Avatar
I can rev all the way to 7500 no problem with them. Idles just fine even with cams.
Old Mar 21, 2016 | 12:46 PM
  #67
Ukchilll's Avatar
What heat exchangers are you 2 running?
I am only really shooting for around 300 whp when I get built. I wouldn't think I would have heat problems running it that easy? Is there a bigger pulley available for it?
Am I crazy to think I can run this de-tuned (highly retarded timing) before I go built?
smooth flow pulleys is where i get my pulleys from and they will make custom sizes keep the revs below 7000 and put a 3.3 or 3.4 pulley on it and tune ignition in the sweet spot its not a good idea simply to retard ignition to get a desired power level
stevehendo34
Mar 11, 2016 10:11 PM
06blackbalt
Feb 10, 2016 08:54 PM
Bigdaddyruffluv
Tuning
Feb 8, 2016 11:21 PM
Foximus
Feb 5, 2016 11:51 PM
MinDKillA
Tuning
Jan 25, 2016 03:25 PM
