What will a total GMPP LS 2 door do 0-60?
Old Aug 6, 2007 | 08:55 PM
Mike85220's Avatar
In other words, I want to know what a Cobalt LS will do 0-60 wise if it has:
-GMPP cat back exhaust
-GMPP extrude honed exhaust manifold
-GMPP ram air intake
Isn't there a ported intake manifold by GMPP also?
One other question, going from steel wheels which I believe the 15s are 20lbs a piece and getting a set of 15lb alloys, how much on the 0-60 in fractions of a second will this shave off?
Thanks all..
Old Aug 6, 2007 | 08:59 PM
The_Blur's Avatar
It depends on a lot of factors like where you live, whether you have an automatic or a manual, and how much else is done to the car (weight reduction, etc.). I imagine it would compare to getting any exhaust, intake, and header—a few horsepower gains (15-25 whp), but nothing like forced induction. The only real way to find out is to take one to the track.
Old Aug 6, 2007 | 09:02 PM
Mike85220's Avatar
Just say the temp outside is 70 degrees, and we are at sea level with an automatic.
I heard on a car that weighs around 2800lbs, 30 hp will knock off 1 second on the 0-60. But again, factors like aerodynamics and the gear ratio come in.
I think the Cobalt is ok aerodynamically and the gearing is good on the automatic.
When I first bought this car, it was sluggish. After 10k miles, it is so much quicker and responsive than what it was originally.
I honestly believe that the write-ups on the 2.2 Cobalt are not accurate on the 0-60. They test drive them when the car was not broken in yet.
Old Aug 6, 2007 | 09:03 PM
OrngBalt's Avatar
Crateenginedepot.com is offering a intake manifold conversion from the 2.2 to 2.4 and they dyno'd 13hp more
13hp for $230
http://www.crateenginedepot.com/stor...t-W67C144.aspx
Old Aug 6, 2007 | 09:09 PM
Mike85220's Avatar
Thanks for the heads up on the 2.4 manifold.
I bet this manifold with the GMPP ram air and a ported tb would be amazing.
Even more so if it was an Injen CAI.
Probably close to 20+hp total gain on the intake side!
Old Aug 6, 2007 | 09:15 PM
chevysalesman614's Avatar
do you know gm has a supercharger kit for the 2.2?
Old Aug 6, 2007 | 09:17 PM
Mike85220's Avatar
I know about that supercharger kit, but it is for the Cavalier and Sunfire and not the Cobalt.
The Cobalt 2.2 has no tuning package as of yet, or do they?
Old Aug 6, 2007 | 09:18 PM
OrngBalt's Avatar
isn't it only for the 2.2 cavi?
There is no tuning so boost = blown up car
just ask yellowshowbalt
Old Aug 7, 2007 | 12:14 AM
Kody's Avatar
im interested... wats the best options here then?
Old Aug 7, 2007 | 08:49 PM
Mike85220's Avatar
The reason I ask about what the 0-60 is on an LS with all the toys GMPP offers is to have a car that is still under warranty.
The SS 2.4 is around a 7.3 second 0-60, the LS is 7.87 seconds.
For the ones who say 8.4 seconds, that is for the 4 door sedan.
If I can get 25 or more horsepower from these upgrades, it should knock off close to a second on the 0-60 as I said that the general consensus has been that a 2800lb car needs 30 or so hp to knock off 1 second on the 0-60 depending on aerodynamics and gearing.
I can only guess that an LS with 25 extra horses will have a 0-60 in 7.3 seconds.I do not want to guess here, as I know there are a few of you that have these mods and have timed their 1/4s and 0-60s.
Anyone with those times please?
Old Aug 7, 2007 | 10:48 PM
RedBaseBolt's Avatar
A full GMPP Cobalt runs about 9.5 seconds in the 1/4
Old Aug 7, 2007 | 10:51 PM
JPizzle's Avatar
I'm guessing, 7.4 seconds. I heard the 2.4 runs like 7.24 seconds 0-60. The Ls/Lt run around 7.9
Old Aug 8, 2007 | 11:08 AM
Red07SSNA's Avatar
Please refrain from drug use when on cobaltss.net....
Old Aug 8, 2007 | 12:44 PM
tonio5555's Avatar
Well if you bought everything in the GMPP build book (not just intake, exhaust) yeah...9.5 is very doable.
Old Aug 8, 2007 | 03:50 PM
Bryank930's Avatar
A full GMPP Cobalt runs about 9.5 minutes in the 1/4
Fixed!!
Old Aug 8, 2007 | 10:24 PM
cobalt9123's Avatar
lol i figure it'll run about 7 seconds in the 0-60, just my opinion, mines running 7.98 or so right now, depending on the temp, and i'm completely stock. I'm guessing 7 flat.
But i'm getting dynos and 0-60's and all that stuff of my STOCK 2.2 so i'll always have reference.
Old Aug 8, 2007 | 10:51 PM
HViper's Avatar
13hp for $230
Just FYI, most of these parts are tested on a stock motor and the posted gains are on a stock motor. Once you start moding a motor you could by say a CAI that is said to increase HP by 15, but that is on a stock motor. On a already modded motor the gains will actulaly be less. You can flame away if you do not belive me, but you will not get the full HP gains from a combination of parts unless it is advertised as a so. For example, say you buy a CAI that claims a 15 HP boost, a cat back that claims a 15 HP boost, and a header that claims also a 15 HP boost. You will really in all reality see about a total gain of around 35-40 HP gain. This can also work in reverse in sertain forced induction engines. You could by exhaust, CAI, and Header DP combination that is suppose to add say 10 HP each for a total of 40 HP. But if you ran this in the combination with say more boost, then the added abilty to flow more air and exhaust with the extra boost could actually net you gains of around 50HP. That is not counting the gains you recieved from running the more boost too. I guess my only point is that you can never count on a manufactors claims of how much HP there product will add, it is the right combination of products combined with the relization of the limits of your motor. Your motor will only be capable of making so much power until you start messing with major stuff like cams, head and valvetrain work, compression, and other major power adders.
Old Aug 9, 2007 | 12:17 AM
At least SOMEONE got the joke! ......nuckleheads...
Old Aug 9, 2007 | 09:49 AM
Bryank930's Avatar
Just a FYI...The intake manifold was on a car with an intake and exhaust already on it.
HEATON
Oct 16, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
