x8xViperx6x's OFFICIAL 2.2SC build
Old Sep 11, 2009 | 05:13 PM
  #101
Jn2's Avatar
Jn2
Originally Posted by x8xViperx6x
its on the intake manifold where the iat2 would normally go, the iat1 sensor doesnt fit so it required sometime of gasket, (I used a small piece of rubber hose cut a hole in it) and also needs something to hold it in, due to it not having the same hole as the iat2 to hold it in place. I used a piece of metal with a hole in it to keep it down. Works.
lol, I think I read it before, really just used stuff lying around.. hey does your pulley get really hot were you cant touch it?
I think im going to try to check the oil level, maybe that has something to do with it..
yes, it will scortch my hand if i try to touch it for more than a faction of a second, **** gets hot, very hot
Old Sep 11, 2009 | 05:15 PM
  #102
x8xViperx6x's Avatar
would appreciate it, just got back from data logging low boost, 0-5psi, seems to have gone well. Did see between 11-10 afr was bouncy since i didnt hold boost to long. But will go from there, did find another problem... meh.. oil is leaking from the dipstick where it meets the pan.. how do I go about fixing that? I think I read somewhere ionninja just took his out I believe.. ill have to research, gotta leave for work in an hour though.. cant drive with an oil leak..
ok, nice, so, were on the same page lol.. the body of the supercharger is touchable, but the snout was boiling hot.. was just making sure.. its getting hotter out iat is now 114* ambient is 100*
Last edited by x8xViperx6x; Sep 11, 2009 at 05:17 PM. Reason: Automerged Doublepost
Old Sep 11, 2009 | 06:03 PM
  #103
Jn2's Avatar
Jn2
u know the ECM monitor IAT at the MAF right? te ambient temp is shown on the DIC, IAT u need a scanner to see, IAT2 is after the intercooler which we cant see...but yeah the pulley will be hot, and just wait till u go with a 2.8...after a few pulls it will burn ur skin to touch the housing...
Old Sep 11, 2009 | 07:27 PM
  #104
iat is on my interceptor my coolant temp shown on the dic was between 199-226* only stayed at 226 for a bit then lowered to 208. I was driving fifty and under with no boost. Its about twenty miles. It was only high at full stops at like red light traffic. Whats everyone elses temps look like?
Old Sep 11, 2009 | 07:31 PM
  #105
Jn2's Avatar
Jn2
yeah the temp the interceptor is showing is IAT at the MAF, which is in your intake, you wont see IAT2 which is in the MAP the LSJ has, which we done have....
Old Sep 11, 2009 | 07:38 PM
  #106
ah ok i understand.. my mistake.
Old Sep 11, 2009 | 07:54 PM
  #107
Gene Culley's Avatar
Talking
Yes gene i did copy because it was much cheaper! and looks way better imo. so thanks lol. i actually just read everyones builds and took here and there.
Ha-ha, no problem. I was just being funny.
I've paid attention to my coolant temp and I've never seen 226, but mine is an LAP which may be tuned differently.
Speak for yourself, lol j/k. There are some of us 2.2's who can see IAT2's.
Last edited by Gene Culley; Sep 11, 2009 at 07:54 PM. Reason: Automerged Doublepost
Old Sep 11, 2009 | 08:01 PM
  #108
ei3dag3's Avatar
haha you mean you just you :P
thats cool how you made it happen though.
Old Sep 11, 2009 | 08:07 PM
  #109
Jn2's Avatar
Jn2
lol there is no "US", just you, yourself, and that guy*point at you*
Old Sep 11, 2009 | 09:52 PM
  #110
What do you normally see after wot? Or sitting at a red? I am running like a very little coolant and mostly water. When i put the radiator hose oni just drained the coolant (most of it) and replaced with water..i figured az doesnt if cold so no worries for freezing.. I may go back to coolant if it keeps it cooler.. It may have air still left in the system maybe..
Old Sep 11, 2009 | 10:40 PM
  #111
SSfamilywagon's Avatar
Your temps are normal. No worries. It's cause your fans don't kick in till around 220ish. My car gets that hot to sometimes. If you hav the ac on the fans will be on all the time. AZ is a bitch with heat. Puts our motors through alot
Old Sep 11, 2009 | 11:20 PM
  #112
i thought i remembered seeing about 216 Ish last year but had to be sure.. Ill just throw in some water wetter. Az is a bish when comes to heat.. Thanks
Old Sep 12, 2009 | 01:48 AM
  #113
as long as it doesn't stay there all the time. It should come back down quick as the fans come on. My average temp during the day is 200 w/ ac on. Mostely 195 at cruise
Old Sep 12, 2009 | 05:48 PM
  #114
Talking
Oh man... somehow I feel picked on here, lol
I live in PA, so I'm going to see lesser temps probably. Even after being supercharged I normally don't see the 200's at all... WOT.. etc. When it was in the mid to high 90's here I did see the 208 or something like that, but it was short lived.
Last edited by Gene Culley; Sep 12, 2009 at 05:48 PM. Reason: Automerged Doublepost
Old Sep 12, 2009 | 06:43 PM
  #115
HunterKiller89's Avatar
i hit 245* sitting in traffic in 110* weather...
so cal does have...a couple down sides
Old Sep 12, 2009 | 06:57 PM
  #116
Ok i feel a lot better.. So whats to hot.. ? It gets fn got here too, very much a downside.. Although at night its not so bad high was like 189-199. Still awaiting vince and an update.. she seems to be running great though.
Old Sep 12, 2009 | 07:52 PM
  #117
anything below 215 is acceptable. If it goes above 215, i'd avoid going WOT till it drops back down. if its above 230, I baby it hardcore, but again, that usually only happens sitting in traffic in excessive heat
Old Sep 13, 2009 | 01:39 AM
  #118
WOW!! I've never see my temps that high. That is actually to high for the motor cause at that point the water is gettin close to boiling. I'd double check your cooling system and do a flush if you haven't yet.
Old Sep 13, 2009 | 04:46 AM
  #119
if he is using water.. Coolant has a higher boiling temp. but thats still real hot. Im thinking about switching back to coolant.. Just cause i dont want it to evaporate..
Old Sep 13, 2009 | 01:42 PM
  #120
The cooling systems on these cars are really great from the factory. Even some of th race cars GM made, still retain an unmodifed cooling system.
Yes coolant helps with boiling but its mostely the system being pressurized that raises the boiling point in the water. If the car is ever gettin above 225 steadily then there is a prob with the system. A leak, faulty thermostat, fans or the cap not holding pressure.
I'm gonna be doing a flush on my cooling and plan on runnng more water then coolant. Gonna do more like a 80/20 water/coolant mix since water cools better then coolant. We rarley see freezing here plus I have a garage to keep the car in, so not worried about it freezing over.
Old Sep 13, 2009 | 04:12 PM
  #121
i think my fans wont turn on. I had some AC issues, and my AC pressure is waaaay low...i think this is affecting my ECU's fan logic negatively....just a guess.
Old Sep 13, 2009 | 09:05 PM
  #122
Just like ssfam said soon as you turn the ac on the fan will kick in i did this just to cool my car at a red. Worked great came down fast. At night i have no probs its 185 at cruise. Oh and still awaiting an update for my tune... Eh.. Gene or anyone else that tuned from trifecta take this long? Im just anxious.
Old Sep 14, 2009 | 03:09 AM
  #123
turning the AC on doesnt turn my fans on. I has broken fanz!
Old Sep 14, 2009 | 03:24 AM
  #124
thats not good... maybe check wiring? Or hot wire it to be sure... Could be a bad relay too probably not likely though.. That sucks..
Old Sep 15, 2009 | 12:21 AM
  #125
Ok great day. Updated tune. Went wot! Only saw 13.5-14psi but in 2nd gear i had the interceptor recording hp it said 291 thats kinda high? Sounds to good to be true is there something i need to change like altitude? Just curious.. Also ambient is off doesnt seen normal.. Going to data log here in a few when it cools abit more.
