ZZP Turbo....Stage 2...2.2...
Old Jun 3, 2010 | 03:53 PM
  #376
conerboner's Avatar
Gotta tune it then I can start it up for the first time... It's alive. Still gotta hook up the exhaust and figure out the boost controller before I take it for a drive though. It's idling at like 1500, hopefully that's cuz it has no back pressure...
Old Jun 3, 2010 | 06:00 PM
  #377
Tundraboarder666's Avatar
Originally Posted by Spanky's Monkey
to be honest i have no clue what it was making before. what's your shift point set at?
Set at 7K right now
Old Jun 3, 2010 | 06:03 PM
  #378
Spanky's Monkey's Avatar
holy hell! try dialing it back a bit. are you using aftermarket valve springs as well?
Old Jun 4, 2010 | 09:14 AM
  #379
conerboner's Avatar
When I start it up the dic says eng power reduced. Does that have to do with the tune or is it from not having exhaust hooked up yet?
Old Jun 4, 2010 | 10:01 AM
  #380
i had that cel show up cause i forgot to plug back up the bank 1 o2. that may not be your problem but you want to triple check all your electronic connections and your intake piping. leave no stone unturned or you may suffer a fate not unlike mine.
Old Jun 4, 2010 | 11:40 AM
  #381
conerboner's Avatar
These are the codes i'm getting. P1516, P0036, P2101, and P2610. One is for the rear O2 so that should be an easy fix. The other ones are with the throttle or something.
Old Jun 4, 2010 | 12:17 PM
  #382
HyperMuffin's Avatar
Engine Power Reduced is most likely the tune. Have you got a tune yet? Also double check to make sure your TB is working. I'm not familiar with turbo's though. Are you using your stock TB or a different TB? If you are using a different TB your wiring may be messed up causing the TB to not work.
Old Jun 4, 2010 | 01:20 PM
  #383
conerboner's Avatar
I uploaded the base tune and I'm using the stock throttle body.
Old Jun 4, 2010 | 01:29 PM
  #384
Hmm well I'm not sure then since I barley know enough to get me by with a SC. Turbos are a whole different language to me. I would ask your tuner about the engine power reduced, and for the TB I would double check make sure your charge piping is on good and just triple checked every hose and bolt, incase you missed something.
Old Jun 4, 2010 | 02:18 PM
  #385
the base tune got me up and running so i son't see why you should be any different. go back and re-check everything and i mean everything.
Old Jun 4, 2010 | 02:21 PM
  #386
No, It loves 7k too much that's where all the power really get squeezed out at. All stock internals for the moment. I've had it go to 7400 before and havn't had a problem.
Old Jun 4, 2010 | 02:30 PM
  #387
conerboner's Avatar
everything is tight and right.... I just sent vince a datalog of it idling so hopefully I can drive it home today and have it for the weekend...
  #388
1LowLS's Avatar
thats because your granny shifting,not double clutching like you should
Old Jun 4, 2010 | 02:34 PM
  #389
on my first blown engine i cracked the #4 rod at 7500 rpm. not looking to do anything like that again..........................
Old Jun 4, 2010 | 03:22 PM
  #390
I'm not telling you to do it to your car... You've blown more than one?
Old Jun 4, 2010 | 04:35 PM
  #391
i'd have to say yeah by default. although i find it hard to accept a failing fuel pump as my fault, but alas it is my car so my fault just the same.
Old Jun 4, 2010 | 06:23 PM
  #392
06_ion2's Avatar
He coulda gave you my base tune? humm well glad you got it idling.
Old Jun 5, 2010 | 01:18 AM
  #393
I'd blame the failed fuel pump on GM honestly, They did send something out to everyone about the fialing fuel pump though as a Re-call. Either way still sucks. You will have to let me know once you get everything back together and running how your tranny is holding up though. Very curious to see what Vince has to say when you can't shift at WOT.
Old Jun 5, 2010 | 07:16 AM
  #394
Cherry GT's Avatar
Sounds to me like the tuner needs to fix the shifting issues.
Mine shifts just fine at WOT and yours should too.
Old Jun 5, 2010 | 02:23 PM
  #395
What it sounds like to me to...
Are you an auto putting down over 260WHP?
Old Jun 5, 2010 | 02:50 PM
  #396
Cherry GT's Avatar
Won't know till wednesday evening.
Old Jun 5, 2010 | 03:03 PM
  #397
Cool you will have to post in here and let me know then.
Old Jun 5, 2010 | 08:32 PM
  #398
Cherry GT's Avatar
I'm just starting to learning all this electronic tranny stuff.
Something has to be messed up in the tune on your shift problems.
I mean these are just some of the WOT shift properties.
Old Jun 6, 2010 | 02:16 AM
  #399
Wow, nice... Yeah that's what I told Vince... But he is convinced that I am overpowering the tranny. He says their is someone with a TVS who is having the same problem. I know my tranny is good till 350 WTQ... I might be pushing 280 and that's on the high side I would think. It's hard to tell him that something is wrong with the tune when he says I'm overpowering the tranny...
We even set it back to stock and tested it and it did not have the same problem... then we put it back to the same settings I had it on but shifting at 6500 and it still had the same problem. Which has me convinced that it is the tune...
Old Jun 7, 2010 | 08:27 AM
  #400
conerboner's Avatar
The new tune didn't work. What else can I do to get my car running again....
