2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
2.2 LAP Mods?
Old Apr 28, 2012 | 05:08 PM
Crav3's Avatar
Oh great sounds good. I don't like raspy sounding exhaust though. Will it make a deeper sound? Cuz i like how my exhaust sounds like now.. it sounds pretty deep and not very loud
Old Apr 29, 2012 | 05:20 PM
cleanxfe's Avatar
Originally Posted by bluebalt07
Cams are not really worth the hassle unless you go turbo or super and are looking to optimize the setup. Because of the variable valve timing I'm not sure anyone even makes cams for the LAP but the last I read someone talking about doing cams it was gonna cost over a grand because of custom work needed to make it work with the VVT and to get the "key" on the end for the cam sensor.
Mounts will stiffen up the engine so that you put more power to the ground and don't get wheel hop.
lap and le5 share the same head so zzp cams should work
Old Apr 29, 2012 | 08:12 PM
Ceej's Avatar
Seems like a lot of people go with badmab headers and zzp dp. That's what I'm going with
Old Apr 29, 2012 | 09:01 PM
Crav3's Avatar
Hmm good to know cleanxfe
And Im going to check on the zzp combo if not ill look into the badmab header and zzp downpipe and see which I like more.. thanks
Also what kind of mounts can I go with? I read here that I would need new mounts if I went on cpilovers because of axle binding?
Old Apr 29, 2012 | 09:27 PM
bluebalt07's Avatar
Did not know that thanks for clearing that up
You definitely wouldn't be disappointed in either of ZZP's combos. As far as mounts if it depends on if you are auto or manual. You can get rotated trans mounts from powell if you are a manual
Old Apr 29, 2012 | 09:30 PM
Crav3's Avatar
I'm auto and are there no mounts for auto?
Old Apr 29, 2012 | 10:16 PM
bluebalt07's Avatar
No. You can get an engine mount but I'm almost positive that is your only option.
Old Apr 30, 2012 | 03:27 PM
Crav3's Avatar
i was looking at some engine mounts on zzp and it says not compatible with auto trans.
also i saw an ls4 throttle body for the LSJ engine. will that fit on my 2.2 with the LSJ throttle body adapter plate?
Old Apr 30, 2012 | 10:55 PM
bluebalt07's Avatar
Try TTR I believe they make engine mounts for auto. And the LS4 tb is over kill on a 2.2. Not sure if it would even work with that adapter plate but the LSJ would be more than enough. Some say it's even too big on the LSJ and makes the throttle feel too sensitive.
Old May 1, 2012 | 02:45 AM
Crav3's Avatar
I'll check them out thanks and I wanted to go with the lsj throttle because I want to go sc in the future and that way I can have the throttle already when I do it
Builttss
Oct 4, 2015 10:21 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
