2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
2.2 lap turbo question
Old Feb 23, 2013 | 01:21 PM
epicpwn's Avatar
i cant find the one answer i need looking over the forums is how much did it cost people to do it themselfs? i have a idea of what it should cost me but i wana make sure.
Old Feb 24, 2013 | 01:08 PM
nhanson's Avatar
Depends on if you piece together yourself or not.
Might get away with 1500-2000 on used parts or 3000+ with a new kit.
Old May 18, 2013 | 08:19 PM
epicpwn's Avatar
I finished it a 1600
Old May 18, 2013 | 08:33 PM
BaDAssCoBalt08's Avatar
With me piecing my turbo build together, it is going to cost me about $3800.
Old May 18, 2013 | 08:34 PM
BankerBalt's Avatar
i spent about 2500
Old May 18, 2013 | 08:35 PM
Originally Posted by BankerBalt
i spent about 2500
Did you buy used parts though?
Old May 18, 2013 | 08:40 PM
BankerBalt's Avatar
yea but not everything. the only new things i bought were the manifold, turbo and blow off valve. everything else was used but they aren't exactly things that would just wear out
Old May 18, 2013 | 09:24 PM
Oh okay cool! well do you mind PMing me a list? because the list I have right about now brings me to at least $3880.
Old May 18, 2013 | 09:29 PM
BankerBalt's Avatar
pm me yours with prices and i will reply with what you don't need/what you should replace it with
Old May 18, 2013 | 10:02 PM
PM'd
Old Feb 22, 2021 | 01:16 AM
BlkBalto2010's Avatar
Please help with my k04 2.2 build
Originally Posted by BaDAssCoBalt08
PM'd
hey man. Did you have trouble installing your turbo onto your LAP with hooking up oil and coolant lines to the block? I’m having issues with this, the main coolant line connects to the same line that the coolant reservoir connects to and I can’t get the hex bolt on the block, oil return line on block and oil feed line on the block because the stupid steering rack is in the way.
Old Feb 2, 2022 | 07:36 PM
LAP-T Rotbox's Avatar
also in same boat do you have to remove the rack to get to the bolts and get them out? Also lap ko4
Old Aug 2, 2022 | 08:50 AM
Weist44's Avatar
Are you having issues with oil drain and feed or the coolant? Oil feed is usually ran off the block off the 6 oil ports. I did my own bung on the pan for drain. If it’s coolant though, I won’t be any help. If this comment is useless, I do apologize
cobaltwizz
Jun 21, 2013 12:32 AM
AzraelRaezier
Oct 6, 2011 09:53 PM
kb2.2lt
Feb 25, 2010 08:29 PM
BlackMachine
Apr 11, 2008 02:04 PM
06LSCobalt
Oct 28, 2005 08:59 AM
