2.2 lap turbo question
i cant find the one answer i need looking over the forums is how much did it cost people to do it themselfs? i have a idea of what it should cost me but i wana make sure.
Please help with my k04 2.2 build
hey man. Did you have trouble installing your turbo onto your LAP with hooking up oil and coolant lines to the block? I’m having issues with this, the main coolant line connects to the same line that the coolant reservoir connects to and I can’t get the hex bolt on the block, oil return line on block and oil feed line on the block because the stupid steering rack is in the way.
Are you having issues with oil drain and feed or the coolant? Oil feed is usually ran off the block off the 6 oil ports. I did my own bung on the pan for drain. If it’s coolant though, I won’t be any help. If this comment is useless, I do apologize
