2.4 throttle body install
sure, your MAF sensor will pick up the extra air rushing in, but your ecu hasnt been told that the throttle position should be changed due to the size difference, which means with no tune, you should either enter limp mode or run like ****.
thats why we're surprised that your running fine without a tune
lol it has everything to do with the wiring and the sensors! if the sensors and wiring are the same then the pcm sees nothing wrong, theres no sensor for tb size, its like putting an intake on it its allowing more air in
there are 2 different types of 2.4 TBs. one is a 6 pin another is an 8 pin.. both need tunes "supposedly" in order to run on a 2.2. a 2.2 "should" need a tune to compensate for this size increase in TB.... makes no sense how this car is running its as simple as that..
well it makes sense that its running, but not that its running well. he probably feels more power from running lean. if i felt like risking my engine i would throw my 2.4 tb on before my tune and watch my wideband to prove my point, but i dont feel like ******* up my engine
LOLOL all the sensors are the same between the two and the throttle position doesn't change still has the same amout of travel between open and closed and the throttle position is determind by how far the pedal is pushed through pulse width modulation
uh you got that mixed up there. why would crate engine depot sell a 2.4 manifold kit clearly stating that you do not need a tune if that was the case?
no no no. theres more air flow at the same throttle position with the 2.4 tb, which means lean.
u really have no idea what your talking about do you..
[QUOTE=drumrush;6054018]no no no. theres more air flow at the same throttle position with the 2.4 tb, which means lean.[/QUOTE
LOL an air intake does the same thing more air
from GM where you getting yours
I don't know much about the LAP but for the l61 (lol?) you do not need a tune for the IM, I am untuned running it right now. I DO NEED a tune if I want to use the 2.4L TB that's on my desk in front of me, my car will not run correctly if I do not get it tuned. The wiring does not change for me either, I have an 8 pin TB stock and AFAIK (what I'm told, I haven't done it yet) the 2.4L 8 pin will plug directly in and work as it should without any repins. I would imagine this is all the same for the LAP but maybe not?
I'm running a 2.4 intake manifold with zzp longtube header gmpp cat back injen intake stock tb and stock tune, car runs great. (07 2.2)
U do not need a tune for the intake manifold
2.4 intake mani without a tune takes away your low end torque and moves it up the power band...
Just saying
Just saying
no, not a score. but i think im done here, nobody seems to understand the point im getting at. an intake will allow more air to enter, yeah. but a larger throttle body needs to be at a different position than the 2.2 to let in the same amount of air. you can get tuned for that. for example (im making up these numbers, but hopefully youll get the idea). lets say that the 2.4 tb is 10 % larger. when at 50% throttle, the 2.4 tb will let in 10% more air because of the larger diameter. therefore throwing off your a/f ratio because the ecu isnt tuned for the difference in diameter. an intake lets more air in, yeah. but the throttle body actually CONTROLS the amount of air that the intake sucks in. comprende?
if you still cant believe that then google search 2.4 TB/IM swaps and see what results you come up with..
